根据给定 M 和 N 方向上的点数以及 M 和 N 方向上的点坐标,创建自由形式的 3D 网格。 支持的平台:仅窗口 签名工 务 局: RetVal = object.Add3Dmesh(M, N, PointsMatrix) 言论顶点可以是彼此之间的任意距离。 ![]() Ais 始终在M和N方向上打开。创建网格后,可以使用对象上的 and 属性关闭网格。PolygonMeshMCloseNClosePolygonMesh Ais 始终创建为简单的网格。创建网格后可以使用属性进行平滑处理。PolygonMeshType 例子工 务 局: Sub Example_Add3DMesh()
' This example creates a 4 X 4 polygonmesh in model space.
Dim meshObj As AcadPolygonMesh
Dim mSize, nSize, count As Integer
Dim points(0 To 47) As Double
' Create the matrix of points
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 2: points(4) = 0: points(5) = 1
points(6) = 4: points(7) = 0: points(8) = 0
points(9) = 6: points(10) = 0: points(11) = 1
points(12) = 0: points(13) = 2: points(14) = 0
points(15) = 2: points(16) = 2: points(17) = 1
points(18) = 4: points(19) = 2: points(20) = 0
points(21) = 6: points(22) = 2: points(23) = 1
points(24) = 0: points(25) = 4: points(26) = 0
points(27) = 2: points(28) = 4: points(29) = 1
points(30) = 4: points(31) = 4: points(32) = 0
points(33) = 6: points(34) = 4: points(35) = 0
points(36) = 0: points(37) = 6: points(38) = 0
points(39) = 2: points(40) = 6: points(41) = 1
points(42) = 4: points(43) = 6: points(44) = 0
points(45) = 6: points(46) = 6: points(47) = 0
mSize = 4: nSize = 4
' creates a 3Dmesh in model space
Set meshObj = ThisDrawing.ModelSpace.Add3DMesh(mSize, nSize, points)
' Change the viewing direction of the viewport to better see the polygonmesh
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
Visual LISP: (vl-load-com)
(defun c:Example_Add3DMesh()
;; This example creates a 4 X 4 polygonmesh in model space.
;; Create the matrix of points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 47)))
(vlax-safearray-fill points '(0 0 0
2 0 1
4 0 0
6 0 1
0 2 0
2 2 1
4 2 0
6 2 1
0 4 0
2 4 1
4 4 0
6 4 0
0 6 0
2 6 1
4 6 0
6 6 0
(setq mSize 4
nSize 4)
;; creates a 3Dmesh in model space
(setq meshObj (vla-Add3DMesh modelSpace mSize nSize points))
;; Change the viewing direction of the viewport to better see the polygonmesh
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-11-12 17:07
