使指定的图形处于活动状态。 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_ActivateMethod()
' This example creates two new drawings and activates each drawing in turn.
Dim NewDrawing1 As AcadDocument
Dim Newdrawing2 As AcadDocument
Set NewDrawing1 = ThisDrawing.Application.Documents.Add("")
Set Newdrawing2 = ThisDrawing.Application.Documents.Add("")
Dim drawing As AcadDocument
For Each drawing In ThisDrawing.Application.Documents
drawing.Activate
MsgBox "Drawing " & drawing.name & " is active."
Next drawing
Visual LISP: Not available |
GMT+8, 2026-10-26 22:40
