该方法将点或位移从一个坐标系转换为另一个坐标系。TranslateCoordinates 称为 OriginalPoint 的点参数可以解释为 3D 点或 3D 位移向量。此参数由布尔参数 Disp 区分。如果 Disp 参数设置为 TRUE,则 OriginalPoint 参数被视为位移向量;否则,它被视为一个点。另外两个参数确定 OriginalPoint 来自哪个坐标系,以及 OriginalPoint 要转换为哪个坐标系。可以在“从”和“到”参数中指定以下 AutoCAD 坐标系:
将 OCS 坐标转换为 WCS 坐标本示例在模型空间中创建折线。然后,折线的第一个折点将同时显示在 OCS 和 WCS 坐标中。从 OCS 到 WCS 的转换要求将 OCS 的法线放在方法的最后一个参数中。TranslateCoordinates Sub Ch8_TranslateCoordinates()
' Create a polyline in model space.
Dim plineObj As AcadPolyline
Dim points(0 To 14) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
' Create a light weight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
' Find the X and Y coordinates of the
' first vertex of the polyline
Dim firstVertex As Variant
firstVertex = plineObj.Coordinate(0)
' Find the Z coordinate for the polyline
' using the elevation property
firstVertex(2) = plineObj.Elevation
' Change the normal for the pline so that the
' difference between the coordinate systems
' is obvious.
Dim plineNormal(0 To 2) As Double
plineNormal(0) = 0#
plineNormal(1) = 1#
plineNormal(2) = 2#
plineObj.Normal = plineNormal
' Translate the OCS coordinate into WCS
Dim coordinateWCS As Variant
coordinateWCS = ThisDrawing.Utility.TranslateCoordinates _
(firstVertex, acOCS, acWorld, False, plineNormal)
' Display the coordinates of the point
MsgBox "The first vertex has the following coordinates:" _
& vbCrLf & "OCS: " & firstVertex(0) & ", " & _
firstVertex(1) & ", " & firstVertex(2) & vbCrLf & _
"WCS: " & coordinateWCS(0) & ", " & _
coordinateWCS(1) & ", " & coordinateWCS(2)
GMT+8, 2026-10-31 11:23
