ActiveX 开发指南
关于指定三维坐标 (VBA/ActiveX)
2023-1-4 21:18| 发布者: admin| 查看: 2381| 评论: 0|来自: AutoCAD
摘要: 输入 3D 世界坐标系 (WCS) 坐标与输入 2D WCS 坐标类似。
输入 3D 世界坐标系 (WCS) 坐标类似于输入 2D WCS 坐标。
除了指定 X 和 Y 值外,还可以指定 Z 值。与 2D 坐标一样,变体用于将坐标传递给 ActiveX® 方法和属性,并查询坐标。
定义和查询 2D 和 3D 折线的坐标
本示例创建两条折线,每条折线都有三个坐标。第一条折线是 2D 折线,第二条折线是 3D 折线。请注意,在创建 3D 折线时,包含顶点的数组的长度将展开以包括 Z 坐标。该示例最后查询折线的坐标并在消息框中显示坐标。
Sub Ch8_Polyline_2D_3D()
    Dim pline2DObj As AcadLWPolyline
    Dim pline3DObj As AcadPolyline
    Dim points2D(0 To 5) As Double
    Dim points3D(0 To 8) As Double
    ' Define three 2D polyline points
   points2D(0) = 1: points2D(1) = 1
   points2D(2) = 1: points2D(3) = 2
   points2D(4) = 2: points2D(5) = 2
    ' Define three 3D polyline points
   points3D(0) = 1: points3D(1) = 1: points3D(2) = 0
   points3D(3) = 2: points3D(4) = 1: points3D(5) = 0
   points3D(6) = 2: points3D(7) = 2: points3D(8) = 0
    ' Create the 2D light weight Polyline
    Set pline2DObj = ThisDrawing.ModelSpace. _
 AddLightWeightPolyline(points2D)
    pline2DObj.Color = acRed
    pline2DObj.Update
    ' Create the 3D polyline
    Set pline3DObj = ThisDrawing.ModelSpace. _
 AddPolyline(points3D)
    pline3DObj.Color = acBlue
    pline3DObj.Update
    ' Query the coordinates of the polylines
    Dim get2Dpts As Variant
    Dim get3Dpts As Variant
    get2Dpts = pline2DObj.Coordinates
    get3Dpts = pline3DObj.Coordinates
    ' Display the coordinates
    MsgBox ("2D polyline (red): " & vbCrLf & _
 get2Dpts(0) & ", " & get2Dpts(1) & vbCrLf & _
 get2Dpts(2) & ", " & get2Dpts(3) & vbCrLf & _
 get2Dpts(4) & ", " & get2Dpts(5))
    MsgBox ("3D polyline (blue): " & vbCrLf & _
 get3Dpts(0) & ", " & get3Dpts(1) & ", " & _
 get3Dpts(2) & vbCrLf & _
 get3Dpts(3) & ", " & get3Dpts(4) & ", " & _
 get3Dpts(5) & vbCrLf & _
 get3Dpts(6) & ", " & get3Dpts(7) & ", " & _
 get3Dpts(8))
GMT+8, 2026-10-28 09:45
