可以使用对象的属性和方法编辑现有样条对象。 使用以下可编辑属性更改样条:
此外,还可以使用以下方法编辑样条曲线:
使用以下只读属性查询样条曲线:
更改样条上的控制点本示例创建一个样条曲线,然后更改样条曲线的第一个控制点。 Sub Ch4_ChangeSplineControlPoint() ' Create the spline Dim splineObj As AcadSpline Dim startTan(0 To 2) As Double Dim endTan(0 To 2) As Double Dim fitPoints(0 To 8) As Double startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0 endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0 fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0 fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0 fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0 Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan) splineObj.Update ' Change the coordinate of the first fit point Dim controlPoint(0 To 2) As Double controlPoint(0) = 0 controlPoint(1) = 3 controlPoint(2) = 0 splineObj.SetControlPoint 0, controlPoint splineObj.Update End Sub 相关概念父主题: |
GMT+8, 2026-11-3 05:17
