对 AutoCAD 2007 和基于 AutoCAD 2007 的产品中的 ActiveX API 所做的添加和更改。 枚举AcEntityName (Changed)
acDwfUnderlay = 46 (New)
acDgnUnderlay = 47 (New)
AcViewportScale (Changed)
acVp1_1 = 2 (New)
acVp1_2 = 3 (New)
acVp1_4 = 4 (New)
acVp1_8 = 5 (New)
acVp1_10 = 6 (New)
acVp1_16 = 7 (New)
acVp1_20 = 8 (New)
acVp1_30 = 9 (New)
acVp1_40 = 10 (New)
acVp1_50 = 11 (New)
acVp1_100 = 12 (New)
acVp2_1 = 13 (New)
acVp4_1 = 14 (New)
acVp8_1 = 15 (New)
acVp10_1 = 16 (New)
acVp100_1 = 17 (New)
acVp1_128in_1ft = 18 (New)
acVp1_64in_1ft = 19 (New)
acVp1_32in_1ft = 20 (New)
acVp1_16in_1ft = 21 (New)
acVp3_32in_1ft = 22 (New)
acVp1_8in_1ft = 23 (New)
acVp3_16in_1ft = 24 (New)
acVp1_4in_1ft = 25 (New)
acVp3_8in_1ft = 26 (New)
acVp1_2in_1ft = 27 (New)
acVp3_4in_1ft = 28 (New)
acVp1in_1ft = 29 (New)
acVp1and1_2in_1ft = 30 (New)
acVp3in_1ft = 31 (New)
acVp6in_1ft = 32 (New)
acVp1ft_1ft = 33 (New)
AcSaveAsType (Changed)
ac2007_dwg = 36 (New)
ac2007_dxf = 37 (New)
ac2007_Template = 38 (New)
acNative = 36 (Changed)
AcValueDataType (New)
acUnknownDataType = 0
acLong = 1
acDouble = 2
acString = 4
acDate = 8
acPoint2d = 16
acPoint3d = 32
acObjectId = 64
acBuffer = 128
acResbuf = 256
acGeneral = 512
AcValueUnitType (New)
acUnitless = 0
acUnitDistance = 1
acUnitAngle = 2
acUnitArea = 4
acUnitVolume = 8
AcParseOption (New)
acParseOptionNone = 0
acSetDefaultFormat = 1
acPreserveMtextFormat = 2
AcFormatOption (New)
kFormatOptionNone = 0
acForEditing = 1
acForExpression = 2
acUseMaximumPrecision = 4
acIgnoreMtextFormat = 8
AcTableStyleOverrides (Changed)
acTitleRowDataType = 24 (New)
acHeaderRowDataType = 25 (New)
acDataRowDataType = 26 (New)
acCellDataType = 148 (New)
AcSectionState (New)
acSectionStatePlane = 1
acSectionStateBoundary = 2
acSectionStateVolume = 4
AcSectionSubItem (New)
acSectionSubItemkNone = 0
acSectionSubItemSectionLine = 1
acSectionSubItemSectionLineTop = 2
acSectionSubItemSectionLineBottom = 4
acSectionSubItemBackLine = 8
acSectionSubItemBackLineTop = 16
acSectionSubItemBackLineBottom = 32
acSectionSubItemVerticalLineTop = 64
acSectionSubItemVerticalLineBottom = 128
AcSectionType (New)
acSectionTypeLiveSection = 1
acSectionType2dSection = 2
acSectionType3dSection = 4
AcSectionGeneration (New)
acSectionGenerationSourceAllObjects = 1
acSectionGenerationSourceSelectedObjects = 2
acSectionGenerationDestinationNewBlock = 16
acSectionGenerationDestinationReplaceBlock = 32
acSectionGenerationDestinationFile = 64
AcHelixConstrainType (New)
acTurnHeight = 0
acTurns = 1
acHeight = 2
AcShadowDisplayType (New)
acCastsAndReceivesShadows = 0
acCastsShadows = 1
acReceivesShadows = 2
acIgnoreShadows = 3
AcLoftedSurfaceNormalType (New)
acRuled = 0
acSmooth = 1
acFirstNormal = 2
acLastNormal = 3
acEndsNormal = 4
acAllNormal = 5
acUseDraftAngles = 6
AcHelixTwistType (New)
acCCW = 0
acCW = 1
类IAcadDatabase (Changed)
SectionManager - Property (New)
Materials - Property (New)
IAcadBlock (Changed)
AddTable - Method (Moved from IAcadBlock2)
Path - Property (Moved from IAcadBlock2)
Comments - Property (Moved from IAcadBlock3)
Units - Property (Moved from IAcadBlock3)
Explodable - Property (Moved from IAcadBlock3)
BlockScaling - Property (Moved from IAcadBlock3)
IsDynamicBlock - Property (Moved from IAcadBlock3)
AddDimArc - Method (Moved from IAcadBlock3)
AddDimRadialLarge - Method (Moved from IAcadBlock3)
AddSection - Method (New)
IAcadEntity (Changed)
Material - Property (New)
IAcadAttribute (Changed)
LockPosition - Property (Moved from IAcadAttribute2)
IAcadAttributeReference (Changed)
LockPosition - Property (Moved from IAcadAttributeReference2)
IAcad3DSolid (Changed)
SolidType - Property (New)
Position - Property (New)
History - Property (New)
ShowHistory - Property (New)
IAcadDimAligned (Changed)
DimensionLinetype - Property (New)
ExtLine1Linetype - Property (New)
ExtLine2Linetype - Property (New)
ExtLineFixedLenSuppress - Property (New)
ExtLineFixedLen - Property (New)
IAcadDimension (Changed)
TextFill - Property (New)
TextFillColor - Property (New)
IAcadDimAngular (Changed)
IAcadDimDiametric (Changed)
IAcadDimRotated (Changed)
IAcadDimOrdinate (Changed)
IAcadDimRadial (Changed)
IAcadMText (Changed)
BackgroundFill - Property (Moved from IAcadMText2)
FieldCode - Method (Moved from IAcadMText2)
IAcadText (Changed)
FieldCode - Method (Moved from IAcadText2)
IAcadBlockReference (Changed)
EffectiveName - Property (Moved from IAcadBlockReference2)
IsDynamicBlock - Property (Moved from IAcadBlockReference2)
GetDynamicBlockProperties - Method (Moved from IAcadBlockReference2)
ResetBlock - Method (Moved from IAcadBlockReference2)
ConvertToAnonymousBlock - Method (Moved from IAcadBlockReference2)
ConvertToStaticBlock - Method (Moved from IAcadBlockReference2)
XEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
YEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
ZEffectiveScaleFactor - Property (Moved from IAcadBlockReference2)
InsUnits - Property (Moved from IAcadBlockReference2)
InsUnitsFactor - Property (Moved from IAcadBlockReference2)
IAcadHatch (Changed)
Area - Property (Moved from IAcadHatch2)
Origin - Property (Moved from IAcadHatch2)
IAcadMLine (Changed)
Justification - Property (Moved from IAcadMLine2)
MLineScale - Property (Moved from IAcadMLine2)
IAcadDim3PointAngular (Changed)
IAcadExternalReference (Changed)
XEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
YEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
ZEffectiveScaleFactor - Property (Moved from IAcadExternalReference2)
InsUnits - Property (Moved from IAcadExternalReference2)
InsUnitsFactor - Property (Moved from IAcadExternalReference2)
IAcadTable (Changed)
RegenerateTableSuppressed - Property (Moved from IAcadTable2)
GetDataType - Method (New)
SetDataType - Method (New)
GetFormat - Method (New)
SetFormat - Method (New)
FormatValue - Method (New)
GetCellDataType - Method (New)
SetCellDataType - Method (New)
GetCellFormat - Method (New)
SetCellFormat - Method (New)
GetCellValue - Method (New)
SetCellValue - Method (New)
SetCellValueFromText - Method (New)
ResetCellValue - Method (New)
IAcadDimArcLength (Changed)
SymbolPosition - Property (New)
IAcadDimRadialLarge (Changed)
IAcadSection (New)
Name - Property
State - Property
ViewingDirection - Property
VerticalDirection - Property
Normal - Property
LiveSectionEnabled - Property
IndicatorTransparency - Property
IndicatorFillColor - Property
Elevation - Property
TopHeight - Property
BottomHeight - Property
NumVertices - Property
Vertices - Property
Coordinate - Property
AddVertex - Method
RemoveVertex - Method
HitTest - Method
CreateJog - Method
Settings - Property
GenerateSectionGeometry - Method
IAcadSectionSettings (New)
CurrentSectionType - Property
GetSectionTypeSettings - Method
IAcadSectionTypeSettings (New)
GenerationOptions - Property
SourceObjects - Property
DestinationBlock - Property
DestinationFile - Property
IntersectionBoundaryColor - Property
IntersectionBoundaryLayer - Property
IntersectionBoundaryLinetype - Property
IntersectionBoundaryLinetypeScale - Property
IntersectionBoundaryPlotStyleName - Property
IntersectionBoundaryLineweight - Property
IntersectionBoundaryDivisionLines - Property
IntersectionFillVisible - Property
IntersectionFillHatchPatternType - Property
IntersectionFillHatchPatternName - Property
IntersectionFillHatchAngle - Property
IntersectionFillHatchScale - Property
IntersectionFillHatchSpacing - Property
IntersectionFillColor - Property
IntersectionFillLayer - Property
IntersectionFillLinetype - Property
IntersectionFillLinetypeScale - Property
IntersectionFillPlotStyleName - Property
IntersectionFillLineweight - Property
IntersectionFillFaceTransparency - Property
BackgroundLinesVisible - Property
BackgroundLinesHiddenLine - Property
BackgroundLinesColor - Property
BackgroundLinesLayer - Property
BackgroundLinesLinetype - Property
BackgroundLinesLinetypeScale - Property
BackgroundLinesPlotStyleName - Property
BackgroundLinesLineweight - Property
ForegroundLinesVisible - Property
ForegroundLinesHiddenLine - Property
ForegroundLinesColor - Property
ForegroundLinesLayer - Property
ForegroundLinesLinetype - Property
ForegroundLinesLinetypeScale - Property
ForegroundLinesPlotStyleName - Property
ForegroundLinesLineweight - Property
ForegroundLinesFaceTransparency - Property
ForegroundLinesEdgeTransparency - Property
CurveTangencyLinesVisible - Property
CurveTangencyLinesColor - Property
CurveTangencyLinesLayer - Property
CurveTangencyLinesLinetype - Property
CurveTangencyLinesLinetypeScale - Property
CurveTangencyLinesPlotStyleName - Property
CurveTangencyLinesLineweight - Property
IAcadPViewport (Changed)
VisualStyle - Property (New)
ModelView - Property (Moved from IAcadPViewport2)
SheetView - Property (Moved from IAcadPViewport2)
LabelBlockId - Property (Moved from IAcadPViewport2)
HasSheetView - Property (Moved from IAcadPViewport2)
SyncModelView - Method (Moved from IAcadPViewport2)
IAcadView (Changed)
CategoryName - Property (Moved from IAcadView2)
LayoutId - Property (Moved from IAcadView2)
LayerState - Property (Moved from IAcadView2)
HasVpAssociation - Property (Moved from IAcadView2)
IAcadGroup (Changed)
IAcadLayers (Changed)
GenerateUsageData - Method (Moved from IAcadLayers2)
IAcadLayer (Changed)
Description - Property (Moved from IAcadLayer2)
Used - Property (Moved from IAcadLayer2)
IAcadSectionManager (New)
Item - Method
Count - Property
GetLiveSection - Method
GetUniqueSectionName - Method
IAcadMaterials (New)
Item - Method
Count - Property
Add - Method
IAcadMaterial (New)
Name - Property
IAcadTableStyle (Changed)
IAcadShadowDisplay (New)
ShadowDisplay - Property
EnableShadowDisplay - Property
IAcadMInsertBlock (Changed)
EffectiveName - Property (Moved from IAcadMInsertBlock2)
IsDynamicBlock - Property (Moved from IAcadMInsertBlock2)
GetDynamicBlockProperties - Method (Moved from IAcadMInsertBlock2)
ResetBlock - Method (Moved from IAcadMInsertBlock2)
ConvertToAnonymousBlock - Method (Moved from IAcadMInsertBlock2)
ConvertToStaticBlock - Method (Moved from IAcadMInsertBlock2)
XEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
YEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
ZEffectiveScaleFactor - Property (Moved from IAcadMInsertBlock2)
InsUnits - Property (Moved from IAcadMInsertBlock2)
InsUnitsFactor - Property (Moved from IAcadMInsertBlock2)
IAcadHelix (New)
Position - Property
Constrain - Property
Height - Property
Turns - Property
TurnHeight - Property
BaseRadius - Property
TopRadius - Property
Twist - Property
TurnSlope - Property
TotalLength - Property
IAcadSurface (New)
SurfaceType - Property
UIsolineDensity - Property
VIsolineDensity - Property
IAcadPlaneSurface (New)
IAcadExtrudedSurface (New)
Height - Property
TaperAngle - Property
IAcadRevolvedSurface (New)
RevolutionAngle - Property
AxisPosition - Property
AxisDirection - Property
IAcadSweptSurface (New)
ProfileRotation - Property
Bank - Property
Twist - Property
scale - Property
Length - Property
IAcadLoftedSurface (New)
NumCrossSections - Property
NumGuidePaths - Property
SurfaceNormals - Property
StartDraftAngle - Property
StartDraftMagnitude - Property
EndDraftAngle - Property
EndDraftMagnitude - Property
Closed - Property
IAcadUnderlay (New)
Contrast - Property
Fade - Property
Position - Property
Rotation - Property
Width - Property
Height - Property
UnderlayName - Property
ItemName - Property
Monochrome - Property
AdjustForBackground - Property
ClipBoundary - Method
File - Property
UnderlayVisibility - Property
ClippingEnabled - Property
IAcadSubEntity (New)
OnModified - Event
ObjectName - Property
color - Property
Layer - Property
Linetype - Property
Hyperlinks - Property
IAcadSubEntSolidFace (New)
Material - Property
IAcadSubEntSolidEdge (New)
IAcadSubEntSolidVertex (New)
IAcadSubEntSolidNode (New)
IAcadModelSpace (Changed)
AddTable - Method (Moved from IAcadModelSpace2)
AddDimArc - Method (Moved from IAcadModelSpace3)
AddDimRadialLarge - Method (Moved from IAcadModelSpace3)
IAcadPaperSpace (Changed)
AddTable - Method (Moved from IAcadPaperSpace2)
AddDimArc - Method (Moved from IAcadPaperSpace3)
AddDimRadialLarge - Method (Moved from IAcadPaperSpace3)
IAcadDocument (Changed)
ActiveMaterial - Property (New)
IAcadPreferencesFiles (Changed)
EnterpriseMenuFile - Property (New)
CustomIconPath - Property (New)
QNewTemplateFile - Property (Moved from IAcadPreferencesFiles2)
PlotLogFilePath - Property (Moved from IAcadPreferencesFiles2)
PageSetupOverridesTemplateFile - Property (Moved from IAcadPreferencesFiles2)
IAcadPreferencesOutput (Changed)
ContinuousPlotLog - Property (Moved from IAcadPreferencesOutput2)
AutomaticPlotLog - Property (Moved from IAcadPreferencesOutput2)
DefaultPlotToFilePath - Property (Moved from IAcadPreferencesOutput2)
IAcadUtility (Changed)
SendModelessOperationStart - Property (Moved from IAcadUtility2)
以下类已删除/与其父类合并: IAcadLayer2 (Removed - Moved to IAcadLayer) IAcadView2 (Removed - Moved to IAcadView) IAcadLayers2 (Removed - Moved to IAcadLayers) IAcadAttribute2 (Removed - Moved to IAcadAttribute) IAcadAttributeReference2 (Removed - Moved to IAcadAttributeReference) IAcadBlockReference2 (Removed - Moved to IAcadBlockReference) IAcadHatch2 (Removed - Moved to IAcadHatch) IAcadMText2 (Removed - Moved to IAcadMText) IAcadText2 (Removed - Moved to IAcadText) IAcadPViewport2 (Removed - Moved to IAcadPViewport) IAcadMInsertBlock2 (Removed - Moved to IAcadMInsertBlock) IAcadMLine2 (Removed - Moved to IAcadMLine) IAcadExternalReference2 (Removed - Moved to IAcadExternalReference) IAcadTable2 (Removed - Moved to IAcadTable) IAcadBlock2 (Removed - Moved to IAcadBlock) IAcadBlock3 (Removed - Moved to IAcadBlock) IAcadModelSpace2 (Removed - Moved to IAcadModelSpace) IAcadModelSpace3 (Removed - Moved to IAcadModelSpace) IAcadPaperSpace2 (Removed - Moved to IAcadPaperSpace) IAcadPaperSpace3 (Removed - Moved to IAcadPaperSpace) IAcadPreferencesFiles2 (Removed - Moved to IAcadPreferencesFiles) IAcadPreferencesOutput2 (Removed - Moved to IAcadPreferencesOutput) IAcadUtility2 (Removed - Moved to IAcadUtility) 相关概念 |
GMT+8, 2026-11-3 17:20
