ActiveX 开发指南
AutoCAD 2019 API 历史记录参考 (ActiveX)
2023-1-5 05:30| 发布者: admin| 查看: 3226| 评论: 0|来自: AutoCAD
摘要: 在 AutoCAD 2019 和基于 AutoCAD 2019 的产品中对 ActiveX API 所做的添加和更改。
对 AutoCAD 2019 和基于 AutoCAD 2019 的产品中的 ActiveX API 所做的添加和更改。
类
AcadAcCmColor
        Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.AcCmColor.23
AcadApplication
        Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.Application.23
AcadLayerStateManager
        Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.AcadLayerStateManager.23
AcadSecurityParams
        Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.SecurityParams.23
IAcadExternalReference (Changed)
        LayerPropertyOverrides - Property (New)
GMT+8, 2026-10-27 03:47
