对 AutoCAD 2014 和基于 AutoCAD 2014 的产品中的 ActiveX API 所做的添加和更改。 枚举AcPointCloudStylizationType (New)
acIntensity = 3
acNormal = 2
acObjectColor = 1
acScanColor = 0
类IAcadApplication
HWND32 - Property (Obsolete; use HWND)
IAcadDatabase
ObjectIDToObject32 - Method (Obsolete; use ObjectIDToObject)
IAcadDocument
IAcadGeoPositionMarker (New)
Altitude - Property
BackgroundFill - Property
DrawingDirection - Property
Height - Property
LandingGap - Property
Latitude - Property
LineSpacingDistance - Property
LineSpacingFactor - Property
LineSpacingStyle - Property
Longitude - Property
Notes - Property
Position - Property
Radius - Property
Rotation - Property
TextFrameDisplay - Property
TextJustify - Property
TextString - Property
TextStyleName - Property
TextWidth - Property
IAcadIDPair
Key32 - Property (Obsolete; use Key)
Value32 - Property (Obsolete; use Value)
IAcadMLeader
GetBlockAttributeValue32 - Method (Obsolete; use GetBlockAttributeValue)
SetBlockAttributeValue32 - Method (Obsolete; use SetBlockAttributeValue)
IAcadObject
ObjectID32 - Property (Obsolete; use ObjectID)
OwnerID32 - Property (Obsolete; use OwnerID)
IAcadPointCloud2 (New)
Stylization - Property
Unit - Property
UnitFactor - Property
IAcadPViewport
LabelBlockId32 - Property (Obsolete; use LabelBlockId)
IAcadTable
GetBlockAttributeValue232 - Method (Obsolete; use GetBlockAttributeValue2)
GetBlockTableRecordId232 - Method (Obsolete; use GetBlockTableRecordId2)
GetBlockTableRecordId32 - Method (Obsolete; use GetBlockTableRecordId)
GetFieldId232 - Method (Obsolete; use GetFieldId2)
GetFieldId32 - Method (Obsolete; use GetFieldId)
GetGridLinetype32 - Method (Obsolete; use GetGridLinetype)
SetBlockAttributeValue232 - Method (Obsolete; use SetBlockAttributeValue2)
SetBlockTableRecordId232 - Method (Obsolete; use SetBlockTableRecordId2)
SetBlockTableRecordId32 - Method (Obsolete; use SetBlockTableRecordId)
SetFieldId232 - Method (Obsolete; use SetFieldId2)
SetFieldId32 - Method (Obsolete; use SetFieldId)
SetGridLinetype32 - Method (Obsolete; use SetGridLinetype)
IAcadTableStyle
GetTextStyleId32 - Method (Obsolete; use GetTextStyleId)
SetTemplateId32 - Method (Obsolete; use SetTemplateId)
SetTextStyleId32 - Method (Obsolete; use SetTextStyleId)
TemplateId32 - Property (Obsolete; use TemplateId)
IAcadUtility
GetSubEntity32 - Method (Obsolete; use GetSubEntity)
ObjectId32ToObjectIdString - Method (Obsolete; use ObjectIdToObjectIdString)
IAcadView
LayoutID32 - Property (Obsolete; use LayoutID)
相关概念 |
GMT+8, 2026-10-27 19:49
