ActiveX 开发指南
AutoCAD 2021 API 历史记录参考 (ActiveX)
2023-1-5 05:42| 发布者: admin| 查看: 3839| 评论: 0|来自: AutoCAD
摘要: 在 中对 ActiveX API 所做的添加和更改 AutoCAD 2021 和 基于 AutoCAD 2021 的产品。
对 AutoCAD 2021 和基于 AutoCAD 2021 的产品中的 ActiveX API 所做的添加和更改。
类
AcadAcCmColor
        Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.AcCmColor.24
AcadApplication
        Major version number of the class has been incremented from 23 to 24
        Use the ProgID AutoCAD.Application.24 to create an instance of AutoCAD 2021.
AcadLayerStateManager
        Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.AcadLayerStateManager.24
AcadSecurityParams
        Version number of the class has been incremented from 23 to 24; use the ProgID AutoCAD.SecurityParams.24
GMT+8, 2026-10-26 02:53
