AutoLISP 开发指南
绘制行
2023-1-5 07:15| 发布者: admin| 查看: 1287| 评论: 0|来自: AutoCAD
看看你是否能理解以下功能。将其与伪代码进行比较,并尝试捕获刚刚描述的几何计算。您可能有一些 AutoLISP 函数对您来说是不熟悉的,如果您需要有关这些功能的帮助,请参阅 AutoLISP 文档。现在,只需阅读代码;不要写任何东西。
(defun gp:Calculate-and-Draw-Tiles (BoundaryData / PathLength
                                    TileSpace TileRadius SpaceFilled SpaceToFill
                                    RowSpacing offsetFromCenter
                                    rowStartPoint pathWidth pathAngle
                                    ObjectCreationStyle TileList)
  (setq PathLength          (cdr (assoc 41 BoundaryData))
        TileSpace           (cdr (assoc 43 BoundaryData))
        TileRadius          (cdr (assoc 42 BoundaryData))
        SpaceToFill         (- PathLength TileRadius)
        RowSpacing          (* (+ TileSpace (* TileRadius 2.0))
                              (sin (Degrees->Radians 60))
                            ) ;_ end of *
        SpaceFilled         RowSpacing
        offsetFromCenter    0.0
        offsetDistance      (/ (+ (* TileRadius 2.0) TileSpace) 2.0)
        rowStartPoint       (cdr (assoc 10 BoundaryData))
        pathWidth           (cdr (assoc 40 BoundaryData))
        pathAngle           (cdr (assoc 50 BoundaryData))
        ObjectCreationStyle (strcase (cdr (assoc 3 BoundaryData)))
  ) ;_ end of setq
  ;; Compensate for the first call to gp:calculate-Draw-tile Row
  ;; in the loop below.
  (setq rowStartPoint
        (polar rowStartPoint
               (+ pathAngle pi)
               (/ TileRadius 2.0)
        ) ;_ end of polar
  ) ;_ end of setq
  ;; Draw each row of tiles.
  (while (<= SpaceFilled SpaceToFill)
    ;; Get the list of tiles created, adding them to our list.
    (setq tileList
          (append tileList
                  (gp:calculate-Draw-TileRow
                    (setq rowStartPoint
                                 pathAngle
                                 RowSpacing
                          ) ;_ end of polar
                    ) ;_ end of setq
                    TileRadius
                    TileSpace
                    pathWidth
                    pathAngle
                    offsetFromCenter
                    ObjectCreationStyle
                  ) ;_ end of gp:calculate-Draw-TileRow
          ) ;_ end of append
          ;; Calculate the distance along the path for the next row.
          SpaceFilled
          (+ SpaceFilled RowSpacing)
          ;; Alternate between a zero and a positive offset
          ;; (causes alternate rows to be indented).
          offsetFromCenter
          (if (= offsetFromCenter 0.0)
            offsetDistance
            0.0
          ) ;_ end of if
    ) ;_ end of setq
  ) ;_ end of while
  ;; Return the list of tiles created.
  tileList
) ;_ end of defun
代码中的几个部分可能需要一些额外的解释。
以下代码片段发生在循环开始之前:while
;; Compensate for the very first start point!!
(setq rowStartPoint(polar rowStartPoint
(+ pathAngle pi)(/ TileRadius 2.0)))
找出该算法背后的逻辑的难题分为三部分:
  • 变量通过分配用户选择作为路径起点的点来开始其在函数内的生命。rowStartPointgp:Calculate-and-Draw-Tiles
  • 传递给函数的第一个参数执行以下操作:gp:calculate-Draw-TileRow
    (setq rowStartPoint(polar rowStartPoint pathAngle RowSpacing))
    另一种说明方式是:在调用函数时,变量设置为超出电流的一个距离。gp:calculate-Draw-TileRowrowStartPointRowSpacingrowStartPoint
  • 参数用作行中圆心的起点。rowStartPointgp:calculate-Draw-TileRow
为了补偿在绘制第一行期间(即通过循环的第一个循环)期间的初始前移,您需要向相反方向略微移动。目的是避免在路径边界和第一行之间出现较大的空白空间。一半的量足以移动点。这可以通过使用沿面向180度的矢量投影来实现。如果您考虑一下,这会将点暂时置于路径边界之外。rowStartPointwhilerowStartPointTileRadiuspolarrowStartPointPathAngle
下一个片段(为可读性而修改)可能有点令人费解:
(setq tileList
  (append tileList
            (setq rowStartPoint
            ) ;_ end of setq
            TileRadius
            TileSpace
            pathWidth
            pathAngle
            offsetFromCenter
            ObjectCreationStyle
从本质上讲,有包裹的,环绕着的调用。setqappendgp:calculate-Draw-TileRow
该函数将返回绘制的每个图块的对象 ID。(对象 ID 指向图形中的平铺对象。您正在逐行绘制磁贴,因此该函数一次返回一行的对象 ID。该函数将新的对象 ID 添加到存储在其中的任何现有对象 ID。gp:calculate-Draw-TileRowappendtileList
; Near the end of the function, you can find the following code fragment:
(setq offsetFromCenter
    offsetDistance
    0.0
这是偏移切换开关,它确定要绘制的行是以路径为中心的圆还是从路径偏移开始。此算法的伪代码如下:
; Set the offset amount to the following:
; If the offset is currently zero, set it to the offset distance;
; Otherwise, set it back to zero.
GMT+8, 2026-10-27 04:46
