AutoLISP 开发指南
*push-error-using-stack*(AutoLISP)
2023-1-5 23:30| 发布者: admin| 查看: 1714| 评论: 0|来自: AutoCAD
摘要: 错误处理函数,指示在自定义中使用 AutoLISP 堆栈中的变量 *错误*处理程序
错误处理函数,指示在自定义处理程序中使用 AutoLISP 堆栈中的变量*error*
支持的平台:视窗和 Mac OS
(*push-error-using-stack*)
没有参数。
返回值
类型:T
返回的值 ofis。T
允许访问自定义处理程序中发生错误的函数中定义的堆栈上的本地 AutoLISP 变量。对函数的调用将覆盖上一个调用。*error**push-error-using-stack**push-error-using-command*
不调用 Iforare,默认情况下,AutoLISP 的工作方式就像被调用一样。*push-error-using-command**push-error-using-stack**push-error-using-stack*
注意:在本地自定义处理程序中使用函数时,不能使用此函数。command*error*
下面的示例演示函数的用法。*push-error-using-stack*
(setq var1 "Global1"      ; Set some global variables
      var2 "Global2")
(defun mySub_err (err_msg)
    (if (/= err_msg "Function cancelled")
      (progn
        (prompt (strcat "\nError: " err_msg))
        (prompt (strcat "\nLocalSub1: " var1))
        (prompt (strcat "\nLocalSub2: " var2))
        (terpri)
    (command-s "._undo" "_e")
    (command-s "._U")
    (setq *error* olderr)
  (princ)
(defun subUtil (val / olderr var1 var2)
    (*push-error-using-stack*)         ; Indicates if the custom error handler has access to local
                                       ; variables defined in his function
    (setq olderr *error*
          *error* mySub_err)
    (command "._undo" "_group")        ; The following will not be executed in this sample, but is good
                                       ; framework for setting up your own error handlers
    (setq var1 "Sub1"                  ; Set some local variables
          var2 "Sub2")
    ;; Perform your tasks here
    (strcat "Foo" val)
    (command "._undo" "_e")
    (setq *error* olderr)              ; Restore old *error* handler
    (*pop-error-mode*)                 ; End the use of *push-error-using-command*
(defun my_err (err_msg)
      (progn
        (prompt (strcat "\nLocal1: " var1))
        (prompt (strcat "\nLocal2: " var2))
        (terpri)
    (command "._U")
  (princ)
(defun myUtil (val / var1 var2)
          *error* my_err)
    (*push-error-using-command*)       ; Indicate use of Command function instead of Command-s
                                       ; in the custom error handler
    (setq var1 "Local1"                ; Set some local variables
          var2 "Local2")
    (subUtil val)                      ; Call to a custom function that uses *push-error-using-stack*
    (/ 1 0)                            ; Call a function with incorrect values to trigger the custom error handler
                                       ; Remove when setting up your code
加载示例代码后,在命令提示符下输入 (myutil 1) 以输入嵌套函数的错误处理程序,并 (myutil “字符串”) 以测试主函数的错误处理程序。
GMT+8, 2026-10-26 14:11
