以下是一个简单的 Visual Basic 6 程序样例,它读取 DXF 文件,并且从给定段的给定对象中提取特定代码和值。 ' ReadDXF extracts specified code/value pairs from a DXF file. ' This function requires four string parameters, a valid DXF ' file name, a DXF section name, the name of an object in that ' section, and a comma delimited list of codes. ' Function ReadDXF( _ ByVal dxfFile As String, ByVal strSection As String, _ ByVal strObject As String, ByVal strCodeList As String) Dim tmpCode, lastObj As String Open dxfFile For Input As #1 ' Get the first code/value pair codes = ReadCodes ' Loop through the whole file until the "EOF" line While codes(1) <> "EOF" ' If the group code is '0' and the value is 'SECTION' .. If codes(0) = "0" And codes(1) = "SECTION" Then ' This must be a new section, so get the next ' code/value pair. codes = ReadCodes() ' If this section is the right one .. If codes(1) = strSection Then ' Get the next code/value pair and .. codes = ReadCodes ' Loop through this section until the 'ENDSEC' While codes(1) <> "ENDSEC" ' While in a section, all '0' codes indicate ' an object. If you find a '0' store the ' object name for future use. If codes(0) = "0" Then lastObj = codes(1) ' If this object is one you're interested in If lastObj = strObject Then ' Surround the code with commas tmpCode = "," & codes(0) & "," ' If this code is in the list of codes .. If InStr(strCodeList, tmpCode) Then ' Append the return value. ReadDXF = ReadDXF & _ codes(0) & "=" & codes(1) & vbCrLf End If End If ' Read another code/value pair codes = ReadCodes Wend End If Else codes = ReadCodes End If Wend Close #1 End Function ' ReadCodes reads two lines from an open file and returns a two item ' array, a group code and its value. As long as a DXF file is read ' two lines at a time, all should be fine. However, to make your ' code more reliable, you should add some additional error and ' other checking. ' Function ReadCodes() As Variant Dim codeStr, valStr As String Line Input #1, codeStr Line Input #1, valStr ' Trim the leading and trailing space from the code ReadCodes = Array(Trim(codeStr), valStr) End Function 相关参考父主题: |
GMT+8, 2025-1-10 06:56
