放置图层上一个记录的开始标记和结束标记 支持的平台:视窗和 Mac OS 签名(acet-layerp-mark [status])
返回值类型:T 或零 T如果开始标记有效;否则。nil 如果省略状态,则返回图层设置的当前标记状态。acet-layerp-mark 言论该函数允许您将多个图层命令分组到单个事务中,以便可以通过发出一次 AutoCAD LAYERP 命令来撤消这些命令。LAYERPMODE 设置必须为 On 才能设置标记。acet-layerp-mark 例子以下代码将图层 0 更改为蓝色,然后在一组开始标记和结束标记之间进行一些额外的图层更改。如果在运行此代码后发出 AutoCAD LAYERP 命令,则图层 0 将恢复为蓝色。 (defun TestLayerP ()
;; Turn LAYERPMODE on, if it is not already
(if (not (acet-layerp-mode))
(acet-layerp-mode T)
;; Set layer 0 to the color blue
(command "._layer" "_color" "blue" "0" "")
;; Set a begin mark
(acet-layerp-mark T)
;; Issue a series of layer commands, and then set an end mark
(command "._layer" "_color" "green" "0" "")
(command "._layer" "_thaw" "*" "")
(command "._layer" "_unlock" "*" "")
(command "._layer" "_ltype" "hidden" "0" "")
(command "._layer" "_color" "red" "0" "")
;; Set an end mark
(acet-layerp-mark nil)
(princ)
GMT+8, 2026-11-26 00:20
