SetVariable 方法 (ActiveX)
2024-5-31 20:43| 发布者: admin| 查看: 685| 评论: 0|原作者: admin|来自: AutoCAD
设置 AutoCAD 系统变量的值。
object.SetVariable Name, Value
类别: 文档
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
要设置的系统变量的名称。
价值
访问:仅输入
类型:变体
指定系统变量的新值。
返回值 (RetVal)
无返回值。
设置系统变量时,AutoCAD 可能需要整数、文本或双精度值。传递错误的数据类型(例如,在需要整数时传递 double 类型的变体)将生成错误。避免这种情况的最简单方法是使用其中一个函数(如 ,在传递数据之前显式键入数据)。CxxxCInt()
有关所有AutoCAD系统变量及其类型的列表,请参见AutoCAD帮助系统中的“系统变量”。
Sub Example_SetVariable()
    ' This example sets various system variables, each of
    ' a different data type.
    Dim sysVarName As String
    Dim sysVarData As Variant
    Dim DataType As Integer
    ' Set FILEDIA system variable (data type Integer) to 1. NOTE that
    ' you need to declare a variable as the data type of system variable,
    ' assign data to that variable and then make it variant type
    Dim intData As Integer
    sysVarName = "FILEDIA"
    intData = 1
    sysVarData = intData    ' Integer data
    ThisDrawing.SetVariable sysVarName, sysVarData
    ' Check the variable using GetVariable
    sysVarData = ThisDrawing.GetVariable(sysVarName)
    MsgBox sysVarName & " = " & sysVarData, , "SetVariable Example"
    ' Set DCTCUST system variable (data type String) to "My Custom Dictionary"
    Dim strData As String
    sysVarName = "DCTCUST"
    strData = "My Custom Dictionary"
    sysVarData = strData        ' String data
    ' Set CHAMFERA system variable (data type Double) to 1.5
    Dim dataDouble As Double
    sysVarName = "CHAMFERA"
    dataDouble = 1.5
    sysVarData = dataDouble ' Double data
    ' Set INSBASE system variable (data type array) to (1.0,1.0,0)
    Dim arrayData3D(0 To 2) As Double
    sysVarName = "INSBASE"
    arrayData3D(0) = 1#: arrayData3D(1) = 1#: arrayData3D(2) = 0
    sysVarData = arrayData3D    ' 3D array data
    MsgBox sysVarName & " = " & sysVarData(0) & ", " & sysVarData(1) & ", " & sysVarData(2), , "SetVariable Example"
(defun c:Example_SetVariable()
    ;; This example sets various system variables, each of
    ;; a different data type.
    ;; Set FILEDIA system variable (data type Integer) to 1. NOTE that
    ;; you need to declare a variable as the data type of system variable,
    ;; assign data to that variable and then make it variant type
    (setq sysVarName "FILEDIA"
          intData 1
          sysVarData intData)    ;; Integer data
    (vla-SetVariable doc sysVarName sysVarData)
    ;; Check the variable using GetVariable
    (setq sysVarData (vlax-variant-value (vla-GetVariable doc sysVarName)))
    (alert (strcat sysVarName " = " (itoa sysVarData)))
    ;; Set DCTCUST system variable (data type String) to "My Custom Dictionary"
    (setq sysVarName "DCTCUST"
           strData "My Custom Dictionary"
           sysVarData strData)        ;; String data
    (alert (strcat sysVarName " = " sysVarData))
    ;; Set CHAMFERA system variable (data type Double) to 1.5
    (setq sysVarName "CHAMFERA"
          dataDouble 1.5
          sysVarData dataDouble)      ;; Double data
    (alert (strcat sysVarName " = " (rtos sysVarData 2)))
    ;; Set INSBASE system variable (data type array) to (1.0,1.0,0)
    (setq sysVarName "INSBASE"
          arrayData3D (vlax-3d-point 1 1 0)
          sysVarData arrayData3D)      ;; 3D array data
    (alert (strcat sysVarName " = " (rtos (vlax-safearray-get-element sysVarData 0) 2) ", "
                                    (rtos (vlax-safearray-get-element sysVarData 1) 2) ", "
                                    (rtos (vlax-safearray-get-element sysVarData 2) 2)))
GMT+8, 2026-10-24 11:54
