实现 AutoCAD 选项板的步骤
2024-5-31 20:10| 发布者: admin| 查看: 836| 评论: 0|原作者: admin|来自: AutoCAD
实现 AutoCAD 选项板的步骤
实现 AutoCAD 选项板的步骤
此 AutoCAD JavaScript 教程演示了如何使用 HTML5 实现调色板,以及如何实现用户与 JavaScript 的交互,以执行在 AutoCAD 中绘制瞬态矩形或圆形等任务。
此 AutoCAD JavaScript 教程演示了如何注册新的透明命令并缩放到所选对象的范围。
在本教程中,您将:
  • 使用 C 在 Manasged .NET 中注册自定义命令#
  • 将 HTML5 文件加载到调色板中
  • 绘制瞬态图形;矩形和圆形使用函数getExtents
  • 使用函数缩放到所选对象的范围zoomExtents
    1. 使用以下 HTML5 和 JavaScript 代码创建在单击调色板上的按钮时调用的命令(JavaScript 函数)以及各种选择方法:
      <html>
         <head>
             <title>Draw a transient circle or rectangle</title>
             <script type="text/javascript" src="https://df-prod.autocad360.com/jsapi/v3/Autodesk.AutoCAD.js ">
             </script>
             <script type="text/javascript">
                 // Some global variables
                 // The cursor for "OnMouseOver", as specified in the UI
                 var cursor = ' ';
                 // Colors for our transient definition, as they are
                 // presented to the user in the UI
                 var colors = new Array();
                 colors['Red'] = "#ff0000";
                 colors['Yellow'] = "#ffff00";
                 colors['Green'] = "#00ff00";
                 colors['Cyan'] = "#00ffff";
                 colors['Blue'] = "#0000ff";
                 colors['Magenta'] = "#ff00ff";
                 colors['White'] = "#ffffff";
                 // Some point information, as populated by user prompting
                 var pt0 = new Array();
                 var pt1 = new Array();
                 var pt2 = new Array();
                 var pt3 = new Array();
                 // Function used to create the XML definition for the
                 // transient rectangular polyline we want to draw
                 function createPolyline() {
                     // Get some parameters from the page
                     var color = document.getElementById('ColCB').value;
                     var linetype = document.getElementById('LTCB').value;
                     var lineweight = document.getElementById('LWCB').value;
                     var filled = document.getElementById('Filled').checked;
                     var cursorType = document.getElementById('Cursor').value;
                     if (cursorType == 'None')
                         cursor = ' ';
                     else
                         cursor = ' cursor="' + cursorType + '"';
                     // Set the other rectangle corners based on the specified corners
                     pt1[0] = pt0[0];
                     pt1[1] = pt2[1];
                     pt1[2] = pt0[2];
                     pt3[0] = pt2[0];
                     pt3[1] = pt0[1];
                     pt3[2] = pt0[2];
                     var drawable =
                       '<?xml version="1.0" encoding="utf-8"?> \
                        <!-- the event handler will receive the id--> \
                        <drawable \
                          xmlns="http://www.autodesk.com/AutoCAD/drawstream.xsd"\
                          xmlns:t="http://www.autodesk.com/AutoCAD/transient.xsd"\
                          t:onmouseover ="onmouseover"'
                           cursor
                           <graphics color="' + colors[color] +
                             '" id="id1" lineweight="' + lineweight +
                             '" linetype="' + linetype +
                             '" filled="' + filled + '">\
                           <polyline isClosed="true">\
                             <vertices>\
                               <vertex>' + pt0.toString() + '</vertex>\
                               <vertex>' + pt1.toString() + '</vertex>\
                               <vertex>' + pt2.toString() + '</vertex>\
                               <vertex>' + pt3.toString() + '</vertex>\
                             </vertices>\
                           </polyline>\
                         </graphics>\
                       </drawable>';
                     return drawable;
                 // transient circle we want to draw
                 function createCircle() {
                         cursor = ' ';
                     else
                     // Use Pythagoras' theorem to get the radius of the circle
                     // based on the points specified
                     var radius =
                       Math.sqrt(
                         Math.pow(pt2[0] - pt0[0], 2) +
                         Math.pow(pt2[1] - pt0[1], 2)
                     var drawable =
                        <drawable \
                          cursor
                            <circle center ="' + pt0.toString() +
                              '" radius ="' + radius.toString() + '"/>\
                          </graphics>\
                        </drawable>';
                     return drawable;
                 // Function used to draw a rectangular transient object
                 function drawRectangularTransient()
                     function on1stComplete(args)
                         var res = args;
                         if (res && res.value)
                             pt0[0] = res.value.x;
                             pt0[1] = res.value.y;
                             pt0[2] = res.value.z;
                             // Once we have the first point, get the other corner
                             var pco =
                                 new Acad.PromptCornerOptions(
                                    'Pick second corner point',
                                    new Acad.Point3d(pt0[0], pt0[1], pt0[2])
                             Acad.Editor.getCorner(pco).then(on2ndComplete, onError);
                     function on2ndComplete(args)
                         var res = args;
                             pt2[0] = res.value.x;
                             pt2[1] = res.value.y;
                             pt2[2] = res.value.z;
                             // And when we have both first and second,
                             // we can generate the XML for the transient
                             // and ask for it to be drawn
                             var doc = Acad.Application.activedocument;
                             var drawable = createPolyline();
                             var tran = new Acad.Transient();
                             doc.transientManager.addTransient(tran, drawable);
                     function onError(args) {
                         alert('Unable to create rectangular transient: ' + args);
                     // The body of our function, where we get the first point
                     var ppo =
                         new Acad.PromptPointOptions(
                            'Pick first corner point',
                            new Acad.Point3d(0, 0, 0)
                     Acad.Editor.getPoint(ppo).then(on1stComplete, onError);
                 // Function used to draw a circle transient object
                 function drawCircularTransient()
                         var res = args;
                             // Once we have the center point, get one on the
                             // circumference
                             var ppo = new Acad.PromptPointOptions('Pick point on circle');
                             ppo.useBasePoint = true;
                             ppo.basePoint = new Acad.Point3d(pt0[0], pt0[1], pt0[2]);
                             Acad.Editor.getPoint(ppo).then(on2ndComplete, onError);
                     function on2ndComplete(args) {
                         var res = args;
                         if (res && res.value) {
                             var drawable = createCircle();
                         alert('Unable to create circle transient: ' + args);
                     var ppo =
                                'Pick center point',
             </script>
             <style type="text/css">
                 td, body {
                     font-family: sans-serif;
                     font-size: 10pt;
                 body {
                     background-color: #686868;
                     padding: 0;
                     margin: 5px 5px 5px 5px;
                     color: #FFF;
                 textarea {
                     font-family: Consolas;
                     font-size: 8pt;
             </style>
         </head>
         <body>
             <!-- Create a tabular UI with headings and comboboxes -->
             <h3>Transient circle or rectangle</h3>
             <table border="0">
                 <tr>
                     <td align='right'>Color</td>
                     <td>
                         <select id='ColCB'>
                             <option selected="selected">Red</option>
                             <option>Yellow</option>
                             <option>Green</option>
                             <option>Cyan</option>
                             <option>Blue</option>
                             <option>Magenta</option>
                             <option>White</option>
                         </select>
                     </td>
                 </tr>
                 <tr>
                     <td align='right'>LineType</td>
                     <td>
                         <select id='LTCB'>
                             <option selected="selected">LineTypeSolid</option>
                             <option>Dashed</option>
                             <option>Dotted</option>
                             <option>Dash_Dot</option>
                             <option>Short_Dash</option>
                             <option>Medium_Dash</option>
                             <option>Long_Dash</option>
                             <option>Short_Dash_X2</option>
                             <option>Medium_Dash_X2</option>
                             <option>Long_Dash_X2</option>
                             <option>Medium_Long_Dash</option>
                             <option>Medium_Dash_Short_Dash_Short_Dash</option>
                             <option>Long_Dash_Short_Dash</option>
                             <option>Long_Dash_Dot_Dot</option>
                             <option>Long_Dash_Dot</option>
                             <option>Medium_Dash_Dot_Short_Dash_Dot</option>
                             <option>Sparse_Dot</option>
                             <option>Solid_6_Pixels_Blank_6_Pixels</option>
                         </select>
                     </td>
                 </tr>
                 <tr>
                     <td align='right'>LineWeight</td>
                     <td>
                         <select id='LWCB'>
                             <option>0</option>
                             <option>5</option>
                             <option>9</option>
                             <option>13</option>
                             <option>15</option>
                             <option>18</option>
                             <option>20</option>
                             <option>25</option>
                             <option selected="selected">30</option>
                             <option>35</option>
                             <option>40</option>
                             <option>50</option>
                             <option>53</option>
                             <option>60</option>
                             <option>70</option>
                             <option>80</option>
                             <option>90</option>
                             <option>100</option>
                             <option>106</option>
                             <option>120</option>
                             <option>140</option>
                             <option>158</option>
                             <option>200</option>
                             <option>211</option>
                         </select>
                     </td>
                 </tr>
                 <tr>
                     <td align='right'>Filled</td>
                     <td><input type='checkbox' id='Filled' /></td>
                 </tr>
                 <tr>
                     <td align='right'>Cursor</td>
                     <td>
                         <select id='Cursor'
                                 title='Cursor to be displayed on hover'>
                             <option selected="selected">None</option>
                             <option>None</option>
                             <option>Arrow</option>
                             <option>Ibeam</option>
                             <option>Wait</option>
                             <option>Cross</option>
                             <option>UpArrow</option>
                             <option>SizeNWSE</option>
                             <option>SizeNESW</option>
                             <option>SizeWE</option>
                             <option>SizeNS</option>
                             <option>SizeAll</option>
                             <option>No</option>
                             <option>Hand</option>
                             <option>AppStarting</option>
                             <option>Help</option>
                         </select>
                     </td>
                 </tr>
                 <tr>
                     <th>&nbsp;</th>
                     <td>
                         <input type='button'
                                style="width: 220px"
                                onclick='drawRectangularTransient()'
                                value='Draw Rectangle Transient' />
                     </td>
                 </tr>
                 <tr>
                     <th>&nbsp;</th>
                     <td>
                                onclick='drawCircularTransient()'
                                value='Draw Circle Transient' />
                     </td>
                 </tr>
            </table>
         </body>
      </html>
    2. 将文件另存为 TransientPalette.html。
    3. 在 Microsoft Visual Studio 中创建或打开 AutoCAD Managed .NET 项目。然后添加以下 C# 代码以将 HTML5 加载到调色板中。
      using Autodesk.AutoCAD.Windows;
      using System;
      namespace JavaScriptLoader
        public class Commands
           static PaletteSet _ps = null;
           [CommandMethod("JSP")]
           public void JavaScriptPalette()
              if (_ps == null)
                 _ps = new PaletteSet(
                              "JavaScript Demo",
                              new Guid("61135FFD-EE9A-4A5D-B3E1-993AB17E93BD")
              if (_ps.Count != 0)
                 _ps[0].PaletteSet.Remove(0);
              var p =
                 _ps.Add(
                    "JavaScript Test",
                    new Uri("http://mywebsite.com/files/" +
                            "TransientPalette.html")
               _ps.Visible = true;
    4. 编译项目并将生成的 DLL 部件加载到 AutoCAD 中。
    5. 在AutoCAD命令提示符下,输入jsp。
      “示例选项板”现在应显示在AutoCAD中。指定要绘制的矩形或圆形瞬态对象的选项,然后单击相应的按钮以绘制该对象。
      使用 JavaScript 和 HTML 的 AutoCAD 中的新选项板
      AutoCAD中使用JavaScript和HTML图像的新调色板
GMT+8, 2026-11-15 12:38
