SliceSolid 方法 (ActiveX)
2024-5-31 18:27| 发布者: admin| 查看: 1000| 评论: 0|原作者: admin|来自: AutoCAD
创建给定定义平面的三个点的 3DSolid 对象的切片。
RetVal = object.SliceSolid(Point1, Point2, Point3, Negative)
类型: 3DSolid
此方法应用到的对象。
第1点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第一个点的 3D WCS 坐标。
第2点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第二个点的 3D WCS 坐标。
第3点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第三个点的 3D WCS 坐标。
阴性
访问:仅输入
类型:布尔
这指定是否返回位于平面负侧的实体部分。如果为 ,则 AutoCAD 将创建一个新对象,该对象包含位于平面负法线侧的原始实体部分。True3DSolid
返回值 (RetVal)
类型: 3DSolid
作为对象生成的切片。3DSolid
Sub Example_SliceSolid()
    ' This example creates a box in model space.
    ' It then slices the box based on a plane
    ' defined by three points. The slice is returned
    ' as a 3Dsolid.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Define the section plane with three points
    Dim slicePt1(0 To 2) As Double
    Dim slicePt2(0 To 2) As Double
    Dim slicePt3(0 To 2) As Double
    slicePt1(0) = 1.5: slicePt1(1) = 7.5: slicePt1(2) = 0
    slicePt2(0) = 1.5: slicePt2(1) = 7.5: slicePt2(2) = 10
    slicePt3(0) = 8.5: slicePt3(1) = 2.5: slicePt3(2) = 10
    ' slice the box
    Dim sliceObj As Acad3DSolid
    Set sliceObj = boxObj.SliceSolid(slicePt1, slicePt2, slicePt3, True)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_SliceSolid()
    ;; This example creates a box in model space.
    ;; It then slices the box based on a plane
    ;; defined by three points. The slice is returned
    ;; as a 3Dsolid.
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
	         boxWidth 7
	         boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Define the section plane with three points
    (setq slicePt1 (vlax-3d-point 1.5 7.5 0)
          slicePt2 (vlax-3d-point 1.5 7.5 10)
          slicePt3 (vlax-3d-point 8.5 2.5 10))
    ;; slice the box
    (setq sliceObj (vla-SliceSolid boxObj slicePt1 slicePt2 slicePt3 :vlax-true))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-27 05:15
