SetSnapSpacing 方法 (ActiveX)
2024-5-31 18:27| 发布者: admin| 查看: 757| 评论: 0|原作者: admin|来自: AutoCAD
设置视口的对齐间距。
object.SetSnapSpacing XSpacing, YSpacing
类型:PViewport、视口
此方法应用到的对象。
XS间距
访问:仅输入
类型:双
X 轴的捕捉间距。
YS间距
访问:仅输入
类型:双
Y 轴的捕捉间距。
返回值 (RetVal)
无返回值。
X 和 Y 间距的初始值为 1.0000。
此值也由 SNAPUNIT 系统变量控制。
Sub Example_SetSnapSpacing()
    ' This example finds the current Snap spacing and changes it.
    ' Find the current active viewport
    Dim viewportObj As AcadViewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Turn on Snap mode and reset the viewport.
    viewportObj.SnapOn = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Find the current Snap spacing
    Dim XSpacing As Double
    Dim YSpacing As Double
    viewportObj.GetSnapSpacing XSpacing, YSpacing
    MsgBox "X =" & XSpacing & ", Y =" & YSpacing, Title:="SetSnapSpacing Example"
    ' Change the Snap spacing
    XSpacing = XSpacing * 0.5
    YSpacing = YSpacing * 0.5
    viewportObj.SetSnapSpacing XSpacing, YSpacing
(defun c:Example_SetSnapSpacing()
    ;; This example finds the current Snap spacing, and changes that spacing.
    ;; Find the current active viewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Turn on Snap spacing and reset the viewport.
    (vla-put-SnapOn viewportObj :vlax-true)
    (vla-put-ActiveViewport doc viewportObj)
    ;; Find the current Snap spacing
    (vla-GetSnapSpacing viewportObj 'XSpacing 'YSpacing)
    (alert (strcat "X =" (rtos XSpacing 2) ", Y =" (rtos YSpacing 2)))
    ;; Change the Snap spacing
    (vla-SetSnapSpacing viewportObj (* XSpacing 0.5) (* YSpacing 0.5))
GMT+8, 2026-11-3 19:35
