SetProjectFilePath 方法 (ActiveX)
2024-5-31 18:27| 发布者: admin| 查看: 662| 评论: 0|原作者: admin|来自: AutoCAD
设置AutoCAD在其中查找外部参考文件的目录。
object.SetProjectFilePath ProjectName, ProjectFilePath
类型:PreferencesFiles
此方法应用到的对象。
项目名称
访问:仅输入
类型:字符串
项目的名称。此名称也由 PROJECTNAME 系统变量控制。
项目文件路径
访问:仅输入
类型:字符串
AutoCAD 在其中查找外部参考文件的目录。
返回值 (RetVal)
无返回值。
Sub Example_SetProjectFilePath()
    ' This example finds the current project file information, changes
    ' that information, and finally resets the information back to the
    ' original values.
    Set preferences = ThisDrawing.Application.preferences
    ' Get the current project file information
    Dim currProjPath As String
    Dim currProjName As Variant
    currProjName = ThisDrawing.GetVariable("PROJECTNAME")
    If currProjName <> "" Then
        currProjPath = preferences.GetProjectFilePath(currProjName)
    End If
    If currProjPath = "" Then
        MsgBox "There is no current project file or path. ", , "SetProjectFilePath Example"
    Else
        MsgBox "The current project file path is: " & currProjPath, , "SetProjectFilePath Example"
        ' Set new project file information.
        ' Change drive/path as necessary to match your system
        Dim newProjPath As String
        newProjPath = "C:/AutoCAD/"
        preferences.SetProjectFilePath currProjName, newProjPath
        MsgBox "The new project file path is: " & newProjPath, , "GetProjectFilePath Example"
        ' Reset the project file information
        preferences.SetProjectFilePath currProjName, currProjPath
        MsgBox "The project file path has been reset to: " & currProjPath, , "GetProjectFilePath Example"
    End If
(defun c:Example_SetProjectFilePath()
    ;; This example finds the current project file information, changes
    ;; that information, and finally resets the information back to the
    ;; original values.
    ;; Get the current project file information
    (setq currProjName (vlax-variant-value (vla-GetVariable doc "PROJECTNAME")))
    (if (/= currProjName "")
        (setq currProjPath (vla-GetProjectFilePath (vla-get-Files preferences) currProjName))
        (setq currProjPath "")
    (if (= currProjPath "")
        (alert "There is no current project file or path. ")
        (progn
	           (alert (strcat "The current project file path is: " currProjPath))
            ;; Set new project file information.
            ;; Change drive/path as necessary to match your system
            (setq newProjPath "C:/AutoCAD/")
            (vla-SetProjectFilePath (vla-get-Files preferences) currProjName newProjPath)
            (alert (strcat "The new project file path is: " newProjPath))
            ;; Reset the project file information
            (vla-SetProjectFilePath (vla-get-Files preferences) currProjName currProjPath)
            (alert (strcat "The project file path has been reset to: " currProjPath))
GMT+8, 2026-11-15 12:29
