SetInvisibleEdge 方法 (ActiveX)
设置边在给定索引处的可见性状态。 支持的平台:仅限 Windows 签名VBA: object.SetInvisibleEdge Index, State
返回值 (RetVal)无返回值。 言论您可以创建一个对象,其中所有边都是不可见的。它不会出现在线框图中,但可以隐藏线条图中的材料。它不会出现在阴影渲染中。3DFace 必须调用该方法才能在图形中显示任何可见性更改。Regen 例子VBA: Sub Example_SetInvisibleEdge()
' This example creates a 3D face in model space.
' It then toggles the visibility of the first edge.
Dim faceObj As Acad3DFace
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim point3(0 To 2) As Double
Dim point4(0 To 2) As Double
' Define the four coordinates of the face
point1(0) = 1#: point1(1) = 1#: point1(2) = 0#
point2(0) = 5#: point2(1) = 1#: point2(2) = 1#
point3(0) = 1#: point3(1) = 10#: point3(2) = 0#
point4(0) = 5#: point4(1) = 5#: point4(2) = 1#
' Create the 3DFace object in model space
Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
ZoomAll
' Find the current visibility status of the first edge of the face
Dim visStatus As Boolean
visStatus = faceObj.GetInvisibleEdge(0)
MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
' Toggle the visibility of the first edge of the face
faceObj.SetInvisibleEdge 0, Not (visStatus)
ThisDrawing.Regen False
MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetInvisibleEdge()
;; This example creates a 3D face in model space.
;; It then toggles the visibility of the first edge.
;; Define the four coordinates of the face
(setq point1 (vlax-3d-point 1 1 0)
point2 (vlax-3d-point 5 1 1)
point3 (vlax-3d-point 5 5 1)
point4 (vlax-3d-point 1 10 0))
;; Create the 3DFace object in model space
(setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4))
(vla-ZoomAll acadObj)
;; Find the current visibility status of the first edge of the face
(setq visStatus (vla-GetInvisibleEdge faceObj 0))
(alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible.")))
;; Toggle the visibility of the first edge of the face
(vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true))
(vla-Regen doc :vlax-false)
(alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible.")))
GMT+8, 2026-10-27 01:22
