AutoCAD 2024 开发者帮助
Acad.Editor.CurrentViewport Function
2024-5-31 18:00| 发布者: admin| 查看: 764| 评论: 0|原作者: admin|来自: AutoCAD
File
Autodesk.AutoCAD.js
Syntax
JavaScript
function Acad.Editor.CurrentViewport();
Group
ACAD Namespace
Description
Represents the current viewport and stores view properties like camera position, target, fieldheight, fieldWidth, upVector, and projection.
Properties
Name Type Description Condition
fieldHeight float Gets the camera field height. Ensure that FieldHeight is not used when the view is in the interactive state. Read-only
fieldWidth float Gets the camera field width. Ensure that FieldWidth is not used when the view is in the interactive state. Read-only
position Acad.Point3d Gets the camera position. Ensure not to use Position when the view is in the interactive state. Read-only
projection Acad.Enum_Projection Gets the projection. Ensure that Projection is not used when the view is in the interactive state. Read-only
target Acad.Point3d Gets the camera target. Ensure not to use Target when the view is in the interactive state. Read-only
upVector Acad.Vector3d Gets the camera up vector. Ensure not to use UpVector when the view is in the interactive state. Read-only
Note: An Error object is thrown if you to set the value of a Read-only property.
ACAD Namespace
GMT+8, 2026-10-25 14:03
