恢复状态
如果指定了 ,则在调用 UNDO 命令时调用对象的函数。该函数是 上的虚函数。派生类可以实现此函数,以解释撤消文件管理器存储的特定于类的信息并读取它。该函数必须确保类执行修改。如果不是,它必须是 super-message,如以下示例所示。kFalseautoUndoapplyPartialUndo()applyPartialUndo()AcDbObjectapplyPartialUndo() 如果要实现部分撤消机制,请务必调用以下函数,以便默认情况下不进行录制。 assertWriteEnabled(kFalse, kFalse); 举个例子,下面是 AsdkPoly 的函数:applyPartialUndo() Acad::ErrorStatus
AsdkPoly::applyPartialUndo(AcDbDwgFiler* filer,
AcRxClass* classObj)
// The first thing to check is whether the class matches
// ours. If it doesn't, we call the base class's
// applyPartialUndo(); hopefully, one of them will
// take care of it.
if (classObj != AsdkPoly::desc())
return AcDbCurve::applyPartialUndo(filer, classObj);
// Read the op-code and call the appropriate "set"
// method to undo what was done. The "set" does the
// filing again for redo.
Adesk::Int16 shortCode;
filer->readItem(&shortCode);
PolyOpCodeForPartialUndo code;
code = (PolyOpCodeForPartialUndo)shortCode;
Adesk::UInt32 value32;
switch (code) {
case kSetNumSides:
filer->readItem(&value32);
AOK(setNumSides(value32));
break;
default:
assert(Adesk::kFalse);
break;
return Acad::eOk;
父主题: |
GMT+8, 2026-10-23 05:21
