SetWidth 方法 (ActiveX)
设置折线的起点和终点宽度(给定线段索引)。 支持的平台:仅限 Windows 签名VBA: object.SetWidth SegmentIndex, StartWidth, EndWidth
返回值 (RetVal)无返回值。 言论线段索引是折线的特定线段的索引。例如,具有三个线段的折线具有线段索引 0、1 和 2。 折线:如果折线属性为 或 ,则此方法将失败。TypeacCubicSplinePolyacQuadSplinePoly 例子VBA: Sub Example_SetWidth()
' The following code prompts you to select a lightweight
' polyline, and then prompts you for the width to set each
' segment of the polyline.
' Pressing ENTER without specifying a width is equivalent to
' entering 0.
Dim returnObj As AcadObject
Dim basePnt As Variant
Dim retCoord As Variant
Dim StartWidth As Double
Dim EndWidth As Double
Dim i, j As Long
Dim nbr_of_segments As Long
Dim nbr_of_vertices As Long
Dim segment As Long
Dim promptStart As String
Dim promptEnd As String
On Error Resume Next
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select a polyline"
' Make sure the user selected a polyline.
If Err <> 0 Then
If returnObj.EntityName <> "AcDbPolyline" Then
MsgBox "You did not select a polyline"
End If
Exit Sub
End If
' Obtain the coordinates of each vertex of the selected polyline.
' The coordinates are returned in an array of points.
retCoord = returnObj.Coordinates
segment = 0
i = LBound(retCoord) ' Start index of coordinates array
j = UBound(retCoord) ' End index of coordinates array
nbr_of_vertices = ((j - i) \ 2) + 1 ' Number of vertices in the polyline
' Determine the number of segments in the polyline.
' A closed polyline has as many segments as it has vertices.
' An open polyline has one fewer segment than it has vertices.
' Check the Closed property to determine if the polyline is closed.
If returnObj.Closed Then
nbr_of_segments = nbr_of_vertices
Else
nbr_of_segments = nbr_of_vertices - 1
End If
' Have user set the width for each segment of the polygon
Do While nbr_of_segments > 0
' Get width values from the user
promptStart = vbCrLf & "Specify the width at the beginning of the segment at " & retCoord(i) & "," & retCoord(i + 1) & " ==> "
promptEnd = vbCrLf & "Now specify the width at the end of that segment ==> "
StartWidth = ThisDrawing.Utility.GetReal(promptStart)
EndWidth = ThisDrawing.Utility.GetReal(promptEnd)
' Set the width of the current segment
returnObj.SetWidth segment, StartWidth, EndWidth
' Prepare to obtain width of next segment, if any
i = i + 2
segment = segment + 1
nbr_of_segments = nbr_of_segments - 1
Loop
MsgBox "Segment widths have been set", , "SetWidth Example"
可视化 LISP: (vl-load-com)
(defun c:Example_SetWidth()
;; The following code prompts you to select a lightweight
;; polyline, then displays the width of each segment of the
;; selected polyline.
(vla-GetEntity (vla-get-Utility doc) 'returnObj 'basePnt "Select a polyline: ")
;; Make sure the user selected a polyline.
(if (/= returnObj nil)
(progn
(if (= (vla-get-ObjectName returnObj) "AcDbPolyline")
(progn
;; Obtain the coordinates of each vertex of the selected polyline.
;; The coordinates are returned in an array of points.
(setq retCoord (vlax-variant-value (vla-get-Coordinates returnObj)))
(setq segment 0
i (vlax-safearray-get-l-bound retCoord 1) ;; Start index of coordinates array
j (vlax-safearray-get-u-bound retCoord 1) ;; End index of coordinates array
nbr_of_vertices (+ (/ (- j i) 2) 1)) ;; Number of vertices in the polyline
;; Determine the number of segments in the polyline.
;; A closed polyline has as many segments as it has vertices.
;; An open polyline has one fewer segment than it has vertices.
;; Check the Closed property to determine if the polyline is closed.
(if (= (vla-get-Closed returnObj) :vlax-true)
(setq nbr_of_segments nbr_of_vertices)
(setq nbr_of_segments (1- nbr_of_vertices))
;; Get the width of each segment of the polyline
(while (>= nbr_of_segments 0)
;; Get width values from the user
(setq promptStart (strcat "\nSpecify the width at the beginning of the segment at " (rtos (vlax-safearray-get-element retCoord i) 2) ","
(rtos (vlax-safearray-get-element retCoord (1+ i)) 2) " ==> "))
(setq promptEnd (strcat "\nNow specify the width at the end of that segment ==> "))
(setq StartWidth (vla-GetReal (vla-get-Utility doc) promptStart))
(setq EndWidth (vla-GetReal (vla-get-Utility doc) promptEnd))
;; Set the width of the current segment
(vla-SetWidth returnObj segment StartWidth EndWidth)
;; Prepare to obtain width of next segment, if any
(setq i (+ i 2)
segment (1+ segment)
nbr_of_segments (1- nbr_of_segments))
(alert "Object selected was not a polyline")
(alert "No object was selected.")
GMT+8, 2026-10-23 19:56
