AutoCAD 2024 开发者帮助
SetRGB 方法 (ActiveX)
2024-5-31 18:00| 发布者: admin| 查看: 718| 评论: 0|原作者: admin|来自: AutoCAD
SetRGB 方法 (ActiveX)
指定“真彩色”的 RGB 值。
object.SetRGB Red, Green, Blue
类型:AcCmColor
此方法应用到的对象。
红
访问:仅输入
类型:长
颜色的红色值。
绿
访问:仅输入
类型:长
颜色的绿色值。
蓝
访问:仅输入
类型:长
颜色的蓝色值。
返回值 (RetVal)
无返回值。
Sub Example_SetRGB()
    ' This example draws a line and returns the RGB values
    Dim line As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    Dim color As AcadAcCmColor
    Set color = line.TrueColor
    color.SetRGB 80, 100, 244
    line.TrueColor = color
    ZoomAll
    Dim retcolor As AcadAcCmColor
    Set retcolor = line.TrueColor
    MsgBox "Red = " & retcolor.Red & vbLf & _
           "Green = " & retcolor.Green & vbLf & _
           "Blue = " & retcolor.Blue
(defun c:Example_SetRGB()
    ;; This example draws a line and returns the RGB values
          doc (vla-get-ActiveDocument acadObj))
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    (setq modelSpace (vla-get-ModelSpace doc)
          line (vla-AddLine modelSpace startPoint endPoint))
    (setq color (vla-get-TrueColor line))
    (vla-SetRGB color 80 100 244)
    (vla-put-TrueColor line color)
    (vla-ZoomAll acadObj)
    (setq retcolor (vla-get-TrueColor line))
    (alert (strcat "Red = " (itoa (vla-get-Red retcolor))
                   "\nGreen = " (itoa (vla-get-Green retcolor))
                   "\nBlue = " (itoa (vla-get-Blue retcolor))
GMT+8, 2026-11-15 13:30
