SetNames 方法 (ActiveX)
指定颜色的颜色名称和书籍名称。 支持的平台:仅限 Windows 签名VBA: object.SetNames ColorName, ColorBook
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_SetNames()
'This example draws a circle and
'returns the color name and color book name of the color.
Dim cir As AcadCircle
Dim pt(0 To 2) As Double
Set cir = ThisDrawing.ModelSpace.AddCircle(pt, 2)
Dim col As AcadAcCmColor
Set col = cir.TrueColor
col.SetRGB 125, 175, 235
col.SetNames "MyColor", "MyColorBook"
cir.TrueColor = col
ZoomAll
Dim retCol As AcadAcCmColor
Set retCol = cir.TrueColor
MsgBox "BookName=" & col.BookName & vbLf & _
"ColorName=" & col.ColorName
可视化 LISP: (vl-load-com)
(defun c:Example_SetNames()
;; This example draws a circle and
;; returns the color name and color book name of the color.
doc (vla-get-ActiveDocument acadObj))
(setq pt (vlax-3d-point 0 0 0))
(setq modelSpace (vla-get-ModelSpace doc)
cir (vla-AddCircle modelSpace pt 2))
(setq col (vla-get-TrueColor cir))
(vla-SetRGB col 125 175 235)
(vla-SetNames col "MyColor" "MyColorBook")
(vla-put-TrueColor cir col)
(vla-ZoomAll acadObj)
(setq retCol (vla-get-TrueColor cir))
(alert (strcat "BookName=" (vla-get-BookName col)
"\nColorName=" (vla-get-ColorName col)
GMT+8, 2026-10-23 10:39
