AutoCAD 2024 开发者帮助
SetInvisibleEdge 方法 (ActiveX)
2024-5-31 18:00| 发布者: admin| 查看: 709| 评论: 0|原作者: admin|来自: AutoCAD
设置边在给定索引处的可见性状态。
object.SetInvisibleEdge Index, State
类型: 3DFace
此方法应用到的对象。
指数
访问:仅输入
类型:
指定要设置的边的索引。索引必须介于 0 和 3(含 0 和 3)之间。
访问:仅输入
类型:布尔
  • True:将边缘设置为不可见。
  • False:将边缘设置为可见。
返回值 (RetVal)
无返回值。
您可以创建一个对象,其中所有边都是不可见的。它不会出现在线框图中,但可以隐藏线条图中的材料。它不会出现在阴影渲染中。3DFace
必须调用该方法才能在图形中显示任何可见性更改。Regen
Sub Example_SetInvisibleEdge()
    ' This example creates a 3D face in model space.
    ' It then toggles the visibility of the  first edge.
    Dim faceObj As Acad3DFace
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    Dim point3(0 To 2) As Double
    Dim point4(0 To 2) As Double
    ' Define the four coordinates of the face
    point1(0) = 1#: point1(1) = 1#: point1(2) = 0#
    point2(0) = 5#: point2(1) = 1#: point2(2) = 1#
    point3(0) = 1#: point3(1) = 10#: point3(2) = 0#
    point4(0) = 5#: point4(1) = 5#: point4(2) = 1#
    ' Create the 3DFace object in model space
    Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
    ZoomAll
    ' Find the current visibility status of the first edge of the face
    Dim visStatus As Boolean
    visStatus = faceObj.GetInvisibleEdge(0)
    MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
    ' Toggle the visibility of the first edge of the face
    faceObj.SetInvisibleEdge 0, Not (visStatus)
    ThisDrawing.Regen False
    MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
(defun c:Example_SetInvisibleEdge()
    ;; This example creates a 3D face in model space.
    ;; It then toggles the visibility of the  first edge.
    ;; Define the four coordinates of the face
    (setq point1 (vlax-3d-point 1 1 0)
          point2 (vlax-3d-point 5 1 1)
          point3 (vlax-3d-point 5 5 1)
          point4 (vlax-3d-point 1 10 0))
    ;; Create the 3DFace object in model space
    (setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4))
    (vla-ZoomAll acadObj)
    ;; Find the current visibility status of the first edge of the face
    (setq visStatus (vla-GetInvisibleEdge faceObj 0))
    (alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible.")))
    ;; Toggle the visibility of the first edge of the face
    (vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true))
    (vla-Regen doc :vlax-false)
    (alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible.")))
GMT+8, 2026-9-12 21:36
