领导者关联性 (.NET)
2024-5-18 19:26| 发布者: admin| 查看: 753| 评论: 0|原作者: admin|来自: AutoCAD
领导者关联性 (.NET)
引线与其注释相关联,因此当注解移动时,引线的端点也会随之移动。移动文本和要素控制框注记时,根据注记与引线倒数第二个(倒数第二个)点的关系,最终引线段在附着到注记的左侧和右侧之间交替。如果注释的中点位于倒数第二个引线点的右侧,则引线附着在右侧;否则,它会附加到左侧。
使用 、 (添加块) 或方法从图形中删除任一对象将破坏关联性。如果在单个操作中将引线及其批注一起复制,则新副本是关联的。如果它们被单独复制,它们将不具有关联性。如果由于任何原因(例如,仅复制 Leader 对象或擦除注释)破坏了关联性,则钩子线将从引线中删除。EraseAddWBlock
将引线关联到批注
此示例创建一个对象。然后,使用对象作为其注释创建引线。MTextMText
VB.NET
<CommandMethod("AddLeaderAnnotation")> _
Public Sub AddLeaderAnnotation()
    '' Get the current database
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create the MText annotation
        Using acMText As MText = New MText()
            acMText.Contents = "Hello, World."
            acMText.Location = New Point3d(5, 5, 0)
            acMText.Width = 2
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acMText)
            acTrans.AddNewlyCreatedDBObject(acMText, True)
            '' Create the leader with annotation
            Using acLdr As Leader = New Leader()
                acLdr.AppendVertex(New Point3d(0, 0, 0))
                acLdr.AppendVertex(New Point3d(4, 4, 0))
                acLdr.AppendVertex(New Point3d(4, 5, 0))
                acLdr.HasArrowHead = True
                acBlkTblRec.AppendEntity(acLdr)
                acTrans.AddNewlyCreatedDBObject(acLdr, True)
                '' Attach the annotation after the leader object is added
                acLdr.Annotation = acMText.ObjectId
                acLdr.EvaluateLeader()
            End Using
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddLeaderAnnotation")]
public static void AddLeaderAnnotation()
    // Get the current database
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create the MText annotation
        using (MText acMText = new MText())
            acMText.Contents = "Hello, World.";
            acMText.Location = new Point3d(5, 5, 0);
            acMText.Width = 2;
            // Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acMText);
            acTrans.AddNewlyCreatedDBObject(acMText, true);
            // Create the leader with annotation
            using (Leader acLdr = new Leader())
                acLdr.AppendVertex(new Point3d(0, 0, 0));
                acLdr.AppendVertex(new Point3d(4, 4, 0));
                acLdr.AppendVertex(new Point3d(4, 5, 0));
                acLdr.HasArrowHead = true;
                acBlkTblRec.AppendEntity(acLdr);
                acTrans.AddNewlyCreatedDBObject(acLdr, true);
                // Attach the annotation after the leader object is added
                acLdr.Annotation = acMText.ObjectId;
                acLdr.EvaluateLeader();
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim leaderObj As AcadLeader
    Dim mtextObj As AcadMText
    Dim points(0 To 8) As Double
    Dim width As Double
    Dim leaderType As Integer
    Dim annotationObject As Object
    Dim textString As String, msg As String
    ' Create the MText object in model space
    textString = "Hello, World."
    insertionPoint(0) = 5
    insertionPoint(1) = 5
    insertionPoint(2) = 0
    width = 2
    Set mtextObj = ThisDrawing.ModelSpace. _
                       AddMText(insertionPoint, width, textString)
    ' Data for Leader
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 4: points(4) = 4: points(5) = 0
    points(6) = 4: points(7) = 5: points(8) = 0
    leaderType = acLineWithArrow
    ' Create the Leader object in model space and associate
    ' the MText object with the leader
    Set annotationObject = mtextObj
    Set leaderObj = ThisDrawing.ModelSpace. _
                        AddLeader(points, annotationObject, leaderType)
    ZoomAll
GMT+8, 2026-11-16 04:45
