为对象分配颜色值 (.NET)
下面的示例创建四个圆圈,并使用四种不同的方法为每个圆圈分配不同的颜色。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
<CommandMethod("SetObjectColor")> _
Public Sub SetObjectColor()
'' Start a transaction
'' Define an array of colors for the layers
Dim acColors(2) As Color
acColors(0) = Color.FromColorIndex(ColorMethod.ByAci, 1)
acColors(1) = Color.FromRgb(23, 54, 232)
acColors(2) = Color.FromNames("PANTONE Yellow 0131 C", _
"PANTONE(R) pastel coated")
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle object and assign it the ACI value of 4
Dim acPt As Point3d = New Point3d(0, 3, 0)
Using acCirc As Circle = New Circle()
acCirc.Center = acPt
acCirc.Radius = 1
acCirc.ColorIndex = 4
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
Dim nCnt As Integer = 0
While (nCnt < 3)
'' Create a copy of the circle
Dim acCircCopy As Circle
acCircCopy = acCirc.Clone()
'' Shift the copy along the Y-axis
acPt = New Point3d(acPt.X, acPt.Y + 3, acPt.Z)
acCircCopy.Center = acPt
'' Assign the new color to the circle
acCircCopy.Color = acColors(nCnt)
acBlkTblRec.AppendEntity(acCircCopy)
acTrans.AddNewlyCreatedDBObject(acCircCopy, True)
nCnt = nCnt + 1
End While
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
using Autodesk.AutoCAD.Colors;
[CommandMethod("SetObjectColor")]
public static void SetObjectColor()
// Start a transaction
// Define an array of colors for the layers
Color[] acColors = new Color[3];
acColors[0] = Color.FromColorIndex(ColorMethod.ByAci, 1);
acColors[1] = Color.FromRgb(23, 54, 232);
acColors[2] = Color.FromNames("PANTONE Yellow 0131 C",
"PANTONE(R) pastel coated");
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle object and assign it the ACI value of 4
Point3d acPt = new Point3d(0, 3, 0);
using (Circle acCirc = new Circle())
acCirc.Center = acPt;
acCirc.Radius = 1;
acCirc.ColorIndex = 4;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
int nCnt = 0;
while (nCnt < 3)
// Create a copy of the circle
Circle acCircCopy;
acCircCopy = acCirc.Clone() as Circle;
// Shift the copy along the Y-axis
acPt = new Point3d(acPt.X, acPt.Y + 3, acPt.Z);
acCircCopy.Center = acPt;
// Assign the new color to the circle
acCircCopy.Color = acColors[nCnt];
acBlkTblRec.AppendEntity(acCircCopy);
acTrans.AddNewlyCreatedDBObject(acCircCopy, true);
nCnt = nCnt + 1;
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub SetObjectColor()
Dim colorObj(2) As New AcadAcCmColor
colorObj(0).ColorMethod = acColorMethodByACI
colorObj(0).ColorIndex = acRed
Call colorObj(1).SetRGB(23, 54, 232)
Call colorObj(2).SetColorBookColor("PANTONE(R) pastel coated", _
"PANTONE Yellow 0131 C")
' Define the center point of the circle
Dim centerPt(0 To 2) As Double
centerPt(0) = 0: centerPt(1) = 3: centerPt(2) = 0
' Create a new circle and assign it the ACI value of 4
Dim circleObj As AcadCircle
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, 1)
circleObj.color = acCyan
Dim nCnt As Integer
' Create 3 more circles
While (nCnt < 3)
Dim circleObjCopy As AcadCircle
Set circleObjCopy = circleObj.Copy
centerPt(1) = centerPt(1) + 3
circleObjCopy.Center = centerPt
circleObjCopy.TrueColor = colorObj(nCnt)
nCnt = nCnt + 1
Wend
相关概念父主题: |
GMT+8, 2026-11-16 04:11
