复制对象 (.NET)
2024-5-18 19:26| 发布者: admin| 查看: 718| 评论: 0|原作者: admin|来自: AutoCAD
复制对象 (.NET)
若要复制对象,请使用为该对象提供的函数。此方法创建一个新对象,该对象是原始对象的副本。创建重复对象后,可以在将其添加或追加到数据库之前对其进行修改。如果不变换对象或更改其位置,则新对象将位于与原始对象相同的位置。Clone
如果要复制大量对象,则可以将每个对象 ID 添加到对象中,然后循环访问每个对象。在循环访问每个对象时,可以对每个对象使用该函数,然后将新对象添加或追加到数据库中。ObjectIdCollectionClone
复制单个对象
下面的示例创建一个新圆,然后创建该圆的直接副本以创建第二个圆。
VB.NET
<CommandMethod("SingleCopy")> _
Public Sub SingleCopy()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle that is at 2,3 with a radius of 4.25
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 3, 0)
            acCirc.Radius = 4.25
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
            '' Create a copy of the circle and change its radius
            Dim acCircClone As Circle = acCirc.Clone()
            acCircClone.Radius = 1
            '' Add the cloned circle
            acBlkTblRec.AppendEntity(acCircClone)
            acTrans.AddNewlyCreatedDBObject(acCircClone, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("SingleCopy")]
public static void SingleCopy()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle that is at 2,3 with a radius of 4.25
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 3, 0);
            acCirc.Radius = 4.25;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
            // Create a copy of the circle and change its radius
            Circle acCircClone = acCirc.Clone() as Circle;
            acCircClone.Radius = 1;
            // Add the cloned circle
            acBlkTblRec.AppendEntity(acCircClone);
            acTrans.AddNewlyCreatedDBObject(acCircClone, true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub SingleCopy()
    ' Define the Circle object
    centerPoint(0) = 2: centerPoint(1) = 3: centerPoint(2) = 0
    ' Define the radius for the initial circle
    Dim radius As Double
    radius = 4.25
    ' Define the radius for the copied circle
    Dim radiusCopy As Double
    radiusCopy = 1#
    ' Add the new circle to model space
    Dim circleObj As AcadCircle
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    Dim circleObjCopy As AcadCircle
    Set circleObjCopy = circleObj.Copy()
    circleObjCopy.radius = radiusCopy
复制多个对象
下面的示例使用对象来跟踪应复制的对象。将对象 ID 添加到集合后,将迭代该集合,并使用该方法创建新对象,然后将其添加到模型空间。ObjectIdCollectionClone
VB.NET
<CommandMethod("MultipleCopy")> _
Public Sub MultipleCopy()
                                        OpenMode.ForWrite)
        '' Create a circle that is at (0,0,0) with a radius of 5
        Using acCirc1 As Circle = New Circle()
            acCirc1.Center = New Point3d(0, 0, 0)
            acCirc1.Radius = 5
            acBlkTblRec.AppendEntity(acCirc1)
            acTrans.AddNewlyCreatedDBObject(acCirc1, True)
            '' Create a circle that is at (0,0,0) with a radius of 7
            Using acCirc2 As Circle = New Circle()
                acCirc2.Center = New Point3d(0, 0, 0)
                acCirc2.Radius = 7
                acBlkTblRec.AppendEntity(acCirc2)
                acTrans.AddNewlyCreatedDBObject(acCirc2, True)
                '' Add all the objects to clone
                Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
                acDBObjColl.Add(acCirc1)
                acDBObjColl.Add(acCirc2)
                For Each acEnt As Entity In acDBObjColl
                    Dim acEntClone As Entity
                    acEntClone = acEnt.Clone()
                    acEntClone.ColorIndex = 1
                    '' Create a matrix and move each copied entity 15 units
                    acEntClone.TransformBy(Matrix3d.Displacement(New Vector3d(15, 0, 0)))
                    '' Add the cloned object
                    acBlkTblRec.AppendEntity(acEntClone)
                    acTrans.AddNewlyCreatedDBObject(acEntClone, True)
                Next
            End Using
        End Using
        acTrans.Commit()
    End Using
C#
[CommandMethod("MultipleCopy")]
public static void MultipleCopy()
        // Create a circle that is at (0,0,0) with a radius of 5
        using (Circle acCirc1 = new Circle())
            acCirc1.Center = new Point3d(0, 0, 0);
            acCirc1.Radius = 5;
            acBlkTblRec.AppendEntity(acCirc1);
            acTrans.AddNewlyCreatedDBObject(acCirc1, true);
            // Create a circle that is at (0,0,0) with a radius of 7
            using (Circle acCirc2 = new Circle())
                acCirc2.Center = new Point3d(0, 0, 0);
                acCirc2.Radius = 7;
                acBlkTblRec.AppendEntity(acCirc2);
                acTrans.AddNewlyCreatedDBObject(acCirc2, true);
                // Add all the objects to clone
                DBObjectCollection acDBObjColl = new DBObjectCollection();
                acDBObjColl.Add(acCirc1);
                acDBObjColl.Add(acCirc2);
                foreach (Entity acEnt in acDBObjColl)
                    Entity acEntClone;
                    acEntClone = acEnt.Clone() as Entity;
                    acEntClone.ColorIndex = 1;
                    // Create a matrix and move each copied entity 15 units
                    acEntClone.TransformBy(Matrix3d.Displacement(new Vector3d(15, 0, 0)));
                    // Add the cloned object
                    acBlkTblRec.AppendEntity(acEntClone);
                    acTrans.AddNewlyCreatedDBObject(acEntClone, true);
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub MultipleCopy()
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    Dim radius1 As Double, radius2 As Double
    radius1 = 5#: radius2 = 7#
    ' Add two circles to the current drawing
    Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
    Set circleObj1 = ThisDrawing.ModelSpace.AddCircle _
                                            (centerPoint, radius1)
    Set circleObj2 = ThisDrawing.ModelSpace.AddCircle _
                                            (centerPoint, radius2)
    ' First put the objects to be copied into a form compatible
    ' with CopyObjects
    Dim objCollection(0 To 1) As Object
    Set objCollection(0) = circleObj1
    Set objCollection(1) = circleObj2
    ' Copy the objects into the model space. A
    ' collection of the new (copied) objects is returned.
    Dim retObjects As Variant
    retObjects = ThisDrawing.CopyObjects(objCollection)
    Dim ptFrom(0 To 2) As Double
    ptFrom(0) = 0: ptFrom(1) = 0: ptFrom(2) = 0
    Dim ptTo(0 To 2) As Double
    ptTo(0) = 15: ptTo(1) = 0: ptTo(2) = 0
    Dim nCount As Integer
    For nCount = 0 To UBound(retObjects)
         Dim entObj As AcadEntity
         Set entObj = retObjects(nCount)
         entObj.color = acRed
         entObj.Move ptFrom, ptTo
    Next
GMT+8, 2026-11-16 01:37
