传递对象库历史记录 (ActiveX/ATO)
对传递对象库所做的添加和更改。 AutoCAD 2025 和基于 AutoCAD 2025 的产品
AutoCAD 2024 和基于 AutoCAD 2024 的产品
AutoCAD 2023 和基于 AutoCAD 2023 的产品
AutoCAD 2022 和基于 AutoCAD 2022 的产品
AutoCAD 2021 和基于 AutoCAD 2021 的产品
AutoCAD 2020 和基于 AutoCAD 2020 的产品
AutoCAD 2019 和基于 AutoCAD 2019 的产品
接口ITransmittalInfo (Changed)
removeDesignFeed - Property (Removed)
AutoCAD 2018 和基于 AutoCAD 2018 的产品
枚举SaveDwgFormat (Changed)
eAutoCADR32 = 7 (New)
AutoCAD 2017 和基于 AutoCAD 2017 的产品
AutoCAD 2016 和基于 AutoCAD 2016 的产品
AutoCAD 2015 和基于 AutoCAD 2015 的产品
枚举ConvertStatus (Changed)
eEduVersionError = 3 (Removed)
eNotUsed = 3 (New)
removeDesignFeed - Property (New)
基于 AutoCAD 2014 和 AutoCAD 2014 的产品
AutoCAD 2013 和基于 AutoCAD 2013 的产品
eAutoCADR27 = 6 (New)
AutoCAD 2012 和基于 AutoCAD 2012 的产品
AutoCAD 2011 和基于 AutoCAD 2011 的产品
AutoCAD 2010 和基于 AutoCAD 2010 的产品
枚举FileType (Changed)
eDGNUnderlayDependent = 25 (New)
eDwsFile = 26 (New)
ePDFUnderlay = 27 (New)
eAutoCADR24 = 5 (New)
BindType (New)
eBind = 0
eInsert = 1
接口ITransmittalFile (Changed)
targetSubPath - Property (Moved from ITransmittalFile2)
type - Property (Moved from ITransmittalFile2)
includeInTransmittal - Property (Moved from ITransmittalFile2)
numberOfDependents - Property (Moved from ITransmittalFile2)
numberOfDependees - Property (Moved from ITransmittalFile2)
database - Property (Moved from ITransmittalFile2)
getDependent - Method (Moved from ITransmittalFile2)
getDependee - Method (Moved from ITransmittalFile2)
ITransmittalFilesGraph (Changed)
add - Method (Removed)
addEdge - Method (Moved from ITransmittalFilesGraph2)
getAt - Method (Moved from ITransmittalFilesGraph2)
getNumberOfFiles - Method (Moved from ITransmittalFilesGraph2)
getRoot - Method (Moved from ITransmittalFilesGraph2)
remove - Method (Removed)
removeEdge - Method (Moved from ITransmittalFilesGraph2)
reset - Method (Moved from ITransmittalFilesGraph2)
totalBytes - Method (Moved from ITransmittalFilesGraph2)
dataLinkRelativePath - Property (Moved from ITransmittalInfo3)
DGNUnderlayRelativePath - Property (Moved from ITransmittalInfo2)
DWFUnderlayRelativePath - Property (Moved from ITransmittalInfo2)
includeDataLinkFile - Property (Moved from ITransmittalInfo3)
includeDGNUnderlay - Property (Moved from ITransmittalInfo2)
includeDWFUnderlay - Property (Moved from ITransmittalInfo2)
includeMaterialTextureFile - Property (Moved from ITransmittalInfo2)
includeNestedOverlayXrefDwg - Property (New)
includePhotometricWebFile - Property (Moved from ITransmittalInfo3)
includeUnloadedReferences - Property (New)
includeUnloadedXrefDwg - Property (New)
overwriteFileHandler - Property (Removed)
purgeDatabase - Property (New)
visualFidelity - Property (Moved from ITransmittalInfo3)
ITransmittalOperation (Changed)
addDrawingFile - Method (Moved from ITransmittalOperation2)
addFile - Method (Moved from ITransmittalOperation2)
addSheets - Method (Moved from ITransmittalOperation2)
addSheetSelset - Method (Moved from ITransmittalOperation2)
addToReport - Method (Moved from ITransmittalOperation2)
archiveSheetSet - Method (Moved from ITransmittalOperation2)
cancelDatabaseNotification - Method (Moved from ITransmittalOperation2)
cancelSheetSetNotification - Method (Moved from ITransmittalOperation2)
cancelSubscriptionToAddFileNotification - Method (Moved from ITransmittalOperation2)
createTransmittalPackage - Method (Moved from ITransmittalOperation2)
getTransmittalGraphInterface - Method (Moved from ITransmittalOperation2)
getTransmittalInfoInterface - Method (Moved from ITransmittalOperation2/ITransmittalOperation3)
getTransmittalReport - Method (Moved from ITransmittalOperation2)
recalcTargetSubPath - Method (Moved from ITransmittalOperation2)
setProgressMeter - Method (Moved from ITransmittalOperation2)
subscribeDatabaseNotification - Method (Moved from ITransmittalOperation2)
subscribeSheetSetNotification - Method (Moved from ITransmittalOperation2)
subscribeToAddFileNotification - Method (Moved from ITransmittalOperation2)
以下接口已删除/与其父类合并: ITransmittalFile2 (Removed - Moved to ITransmittalFile) ITransmittalFilesGraph2 (Removed - Moved to ITransmittalFilesGraph) ITransmittalInfo2 (Removed - Moved to ITransmittalInfo) ITransmittalInfo3 (Removed - Moved to ITransmittalInfo) ITransmittalOperation2 (Removed - Moved to ITransmittalOperation) ITransmittalOperation3 (Removed - Moved to ITransmittalOperation) AutoCAD 2009 和基于 AutoCAD 2009 的产品
枚举DwgTrustInfo (New)
eDwgUnTrusted = 0xffffffff
eTrustInfoUnavailable = 0
eDwgTrusted = 1
ConvertStatus (New)
eConverted = 0
eSaveError = 1
eRecovered = 2
eShareViolationError = 4
eMissingFiles = 5
eSignedFileError = 6
接口ITransmittalFileOperationOverride (New)
Open - Method (New)
Close - Method (New)
PreProcessHandling - Method (New)
AutoCAD 2008 和基于 AutoCAD 2008 的产品
ePhotometricWebFile = 23 (New)
eDataLinkFile = 24 (New)
接口ITransmittalInfo3 (New)
dataLinkRelativePath - Property (New)
includeDataLinkFile - Property (New)
includePhotometricWebFile - Property (New)
visualFidelity - Property (New)
ITransmittalOperation3 (New)
getTransmittalInfoInterface - Method (New)
ITransmittalFilesGraphPrivate (Changed)
add - Method (Changed to support 64-bit)
nodeAt - Method (Changed to support 64-bit)
AutoCAD 2007 和基于 AutoCAD 2007 的产品
eDGNUnderlay = 20 (New)
eDWFUnderlay = 21 (New)
eMaterialTextureFile = 22 (New)
eAutoCADR21 = 4 (New)
接口ITransmittalInfo2 (Changed)
DGNUnderlayRelativePath - Property (New)
DWFUnderlayRelativePath - Property (New)
includeDGNUnderlay - Property (New)
includeDWFUnderlay - Property (New)
includeMaterialTextureFile - Property (New)
AutoCAD 2006 和基于 AutoCAD 2006 的产品
AutoCAD 2005 和基于 AutoCAD 2005 的产品
eXrefAttachFile = 16 (New)
eXrefOverlayFile = 17 (New)
eSheetSetFile = 18 (New)
eSheetSetSupportFile = 19 (New)
AddFileReturnVal (Changed)
eFileAlreadyAdded = 5 (New)
接口ITransmittalDatabaseNotificationHandler (New)
convertDatabase - Method
postDatabaseProcessing - Method
preDatabaseProcessing - Method
ITransmittalFile2 (New)
database - Property
fileExists - Property
fileSize - Property
lastModifiedTime - Property
sourcePath - Property
type - Property
version - Property
ITransmittalFilesGraph2 (New)
addEdge - Method
getAt - Method
getRoot - Method
removeEdge - Method
reset - Method
totalBytes - Method
ITransmittalInfo2 (New)
defaultOverwriteValue - Property
destinationRoot - Property
imageRelativePath - Property
includeFontFile - Property
includeImageFile - Property
includePlotFile - Property
includeXrefDwg - Property
organizedFolder - Property
plotConfigFilePath - Property
plotStyleTablePath - Property
preserveSubdirs - Property
relativePath - Property
resetPlotter - Property
saveVersion - Property
xrefRelativePath - Property
ITransmittalProgressHandler (New)
isCanceled - Method
processingFile - Method
ITransmittalOperation2 (New)
addFile - Method
addSheets - Method
ITransmittalSheetSetNotification (New)
preSheetSetProcessing - Method
postSheetSetProcessing - Method
AutoCAD 2004 和基于 AutoCAD 2004 的产品
相关参考 |
GMT+8, 2026-11-16 02:04
