ObjectErased 事件 (ActiveX)
2024-5-18 19:22| 发布者: admin| 查看: 1056| 评论: 0|原作者: admin|来自: AutoCAD
当对象从图形中删除时触发。
object.ObjectErased(ObjectID)
类别: 文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是文档。
对象 ID
类型:LONG_PTR;输入到处理程序
已擦除的对象的对象 ID。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long_PTR)
    ' This example intercepts a drawing ObjectErased event.
    ' This event is triggered when an object is removed from a drawing.
    ' To trigger this example event: Delete (Cut) an existing object from an open drawing
    ' Use the "Object" variable to determine the type of object removed
    MsgBox "The ID of the object deleted is: " & ObjectID
Not available
GMT+8, 2026-11-16 04:22
