修改的事件 (ActiveX)
2024-5-18 19:22| 发布者: admin| 查看: 1001| 评论: 0|原作者: admin|来自: AutoCAD
修改的事件 (ActiveX)
在修改图形中的对象或集合时触发。
object.Modified(Entity)
类型:所有绘图对象、块、块、字典、字典、DimStyle、DimStyles、组、组、层、层、布局、布局、线型、线型、材质、MLeaderStyle、ModelSpace、PaperSpace、 PlotConfiguration、PlotConfigurations、RegisteredApplication、RegisteredApplications、SectionManager、SectionSettings、SectionTypeSettings、SortentsTable、TableStyle、TextStyle、TextStyles、UCS、UCS、视图、视口、视口、视图、 XRecord的
计算结果为有效容器对象的对象表达式。
实体
类型:图形对象
图形中被修改的对象可以是任何一个图形对象。
每当修改对象时,都会触发此事件。修改包括设置属性值的时间,即使新值等于当前值也是如此。
在 VBA 中编码时,必须为为该事件启用的所有对象提供事件处理程序。如果不提供处理程序,VBA 可能会意外终止。Modified
显示模式对话框时不会触发任何事件。
Public WithEvents PLine As AcadLWPolyline    ' Use with Modified Event Example
Sub Example_Modified()
    ' This example creates a lightweight polyline in model space and
    ' references the PolyLine using the public variable (PLine) which
    ' is set up to intercept Modified events.
    ' This example then modifies the new object, triggering the code
    ' in the Modified event.
    Dim points(0 To 9) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 2
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 4
    ' Create a lightweight Polyline object in model space
    ' * Note: We are returning the new PolyLine object into a Module
    ' level variable.  This allows us to intercept events associated
    ' with that particular object.
    Set PLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ' Modify object to trigger event.
    ' * Note: The event code for the PolyLine modification will be triggered
    ' before we move forward and refresh the view, so the line will not
    ' appear blue when the event message box is displayed.
    Dim color As AcadAcCmColor
    Set color = PLine.TrueColor
    Call color.SetRGB(80, 100, 244)
    PLine.TrueColor = color
Private Sub PLine_Modified(ByVal pObject As AutoCAD.IAcadObject)
    ' This example intercepts an object's Modified event.
    ' This event is triggered when an object supporting this event is modified.
    ' To trigger this code: Modify an object connected to this event
    ' * Note: By connected, we mean the object set up to intercept events using
    ' the VBA WithEvents statement
    ' Use the "pObject" variable to determine which object was modified
    MsgBox "You just modified an object with an ID of: " & pObject.ObjectID
Not available
GMT+8, 2026-11-16 02:53
