Visible 属性 (ActiveX)
2024-5-18 19:22| 发布者: admin| 查看: 722| 评论: 0|原作者: admin|来自: AutoCAD
指定对象或应用程序的可见性。
object.Visible
类型:所有图形对象、应用程序、属性参照、组、工具栏
此属性应用于的对象
只读:否(对象除外)Group
类型:布尔
  • True:对象或应用程序可见。
  • False:对象或应用程序不可见。
如果将对象指定为不可见对象,则无论应用程序可见设置如何,该对象都将不可见。其他因素也可能导致物体不可见;例如,如果对象的图层处于关闭状态或冻结状态,则不会显示该对象。
将应用程序指定为不可见,允许您在后台运行任务,而无需查看组件。
Sub Example_Visible()
    ' This example creates a line in model space.
    ' It then turns visibility of the line on or off, depending
    ' on the user's choice.
    Dim lineObj As AcadLine
    ' Create the line
    startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
    endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
    ZoomAll
    Dim response As Integer
    response = MsgBox("Do you want the new line to be visible?", vbYesNoCancel + vbQuestion)
    Select Case response
    Case vbYes
        lineObj.Visible = True
    Case vbNo
        lineObj.Visible = False
    Case vbCancel
        Exit Sub
    End Select
    ThisDrawing.Regen True
(defun c:Example_Visible()
    ;; This example creates a line in model space.
    ;; It then turns visibility of the line on or off, depending
    ;; on the user's choice.
          doc (vla-get-ActiveDocument acadObj))
    ;; Create the line
    (setq startPoint (vlax-3d-point 2 2 0)
          endPoint (vlax-3d-point 4 4 0))
    (setq modelSpace (vla-get-ModelSpace doc)
          lineObj (vla-AddLine modelSpace startPoint endPoint))
    (vla-ZoomAll acadObj)
    (setq kwordList "Yes No")
    (vla-InitializeUserInput (vla-get-Utility doc) 1 kwordList)
    (setq response (vla-GetKeyword (vla-get-Utility doc) "Do you want the new line to be visible? [Yes/No]: "))
    (cond
        ((= response "Yes") (vla-put-Visible lineObj :vlax-true))
        ((= response "No") (vla-put-Visible lineObj :vlax-false))
    (vla-Regen doc :vlax-true)
GMT+8, 2026-11-16 04:07
