Utility 属性 (ActiveX)
2024-5-18 19:22| 发布者: admin| 查看: 1060| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 Utility 对象。
object.Utility
类别: 文档
此属性应用于的对象。
只读:是的
类型: 实用程序
文档的 Utility 对象。
Sub Example_Utility()
    ' This example creates a spline in model space using the
    ' CreateTypedArray method off of the utility object.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan As Variant
    Dim endTan As Variant
    Dim fitPoints As Variant
    Dim utilObj As Object   ' CreateTypedArray needs to be a late bound object
    Set utilObj = ThisDrawing.Utility
    utilObj.CreateTypedArray startTan, vbDouble, 0.5, 0.5, 0
    utilObj.CreateTypedArray endTan, vbDouble, 0.5, 0.5, 0
    utilObj.CreateTypedArray fitPoints, vbDouble, 1, 1, 0, 5, 5, 0, 10, 0, 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
(defun c:Example_Utility()
    ;; This example creates a spline in model space using the
    ;; CreateTypedArray method off of the utility object.
    ;; Create the spline
    (setq utilObj (vla-get-Utility doc))
    (vla-CreateTypedArray utilObj 'startTan vlax-vbDouble 0.5 0.5 0)
    (vla-CreateTypedArray utilObj 'endTan vlax-vbDouble 0.5 0.5 0)
    (vla-CreateTypedArray utilObj 'fitPoints vlax-vbDouble 0 0 0 5 5 0 10 0 0)
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
GMT+8, 2026-11-16 04:19
