TolerancePrecision 属性 (ActiveX)
2024-5-18 19:22| 发布者: admin| 查看: 1007| 评论: 0|原作者: admin|来自: AutoCAD
指定公差值在主要尺寸中的精度。
object.TolerancePrecision
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimPrecision
  • acDimPrecisionZero: 0.
  • acDimPrecisionOne: 0.0
  • acDimPrecisionTwo: 0.00
  • acDimPrecisionThree: 0.000
  • acDimPrecisionFour: 0.0000
  • acDimPrecisionFive: 0.00000
  • acDimPrecisionSix: 0.000000
  • acDimPrecisionSeven: 0.0000000
  • acDimPrecisionEight: 0.00000000
此属性的初始值为 。acDimPrecisionFour
仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone
注意:此属性将覆盖给定维度的 DIMTDEC 系统变量的值。
Sub Example_TolerancePrecision()
    ' uses TolerancePrecision to allow the user to change the
    ' precision of the dimension tolerance
    Dim dimObj As AcadDimAligned
    Dim oldTolerance As String, newTolerance As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    dimObj.ToleranceLowerLimit = -0.0001
    dimObj.ToleranceUpperLimit = 0.005
    ' Store old tolerance value as default for input box
    oldTolerance = dimObj.TolerancePrecision
    ' Allow the user to change the precision for the dimension tolerance
    newTolerance = InputBox("Enter a new tolerance precision for the dimension.  The value must range from 0 to 8.", "Dimension Tolerance Precision", oldTolerance)
    Select Case newTolerance
        Case 0: newTolerance = acDimPrecisionZero
        Case 1: newTolerance = acDimPrecisionOne
        Case 2: newTolerance = acDimPrecisionTwo
        Case 3: newTolerance = acDimPrecisionThree
        Case 4: newTolerance = acDimPrecisionFour
        Case 5: newTolerance = acDimPrecisionFive
        Case 6: newTolerance = acDimPrecisionSix
        Case 7: newTolerance = acDimPrecisionSeven
        Case 8: newTolerance = acDimPrecisionEight
        Case Else
            MsgBox "The tolerance precision has not been changed."
            Exit Sub
    End Select
    dimObj.TolerancePrecision = newTolerance   ' Commit changes to tolerance precision
    ' Read back and display the dimension tolerance precision
    newTolerance = dimObj.TolerancePrecision
    MsgBox "The tolerance precision has been set to " & newTolerance & " decimal places"
(defun c:Example_TolerancePrecision()
    ;; uses TolerancePrecision to allow the user to change the
    ;; precision of the dimension tolerance
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.12345678 5 0)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-put-ToleranceLowerLimit dimObj -0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.005)
    (vla-ZoomAll acadObj)
    ;; Store old tolerance value as default for input box
    (setq oldTolerance (vla-get-TolerancePrecision dimObj))
    ;; Allow the user to change the precision for the dimension tolerance
    (setq newTolerance (vla-GetInteger (vla-get-Utility doc) (strcat "\nEnter a new tolerance precision for the dimension (0 to 8) <" (itoa oldTolerance) ">: ")))
    (if (= newTolerance nil) (setq newTolerance oldTolerance))
    (setq newTolerance (cond
                           ((= newTolerance 0) acDimPrecisionZero)
                           ((= newTolerance 1) acDimPrecisionOne)
                           ((= newTolerance 2) acDimPrecisionTwo)
                           ((= newTolerance 3) acDimPrecisionThree)
                           ((= newTolerance 4) acDimPrecisionFour)
                           ((= newTolerance 5) acDimPrecisionFive)
                           ((= newTolerance 6) acDimPrecisionSix)
                           ((= newTolerance 7) acDimPrecisionSeven)
                           ((= newTolerance 8) acDimPrecisionEight)
                           (progn (setq newTolerance nil) (alert "The tolerance precision has not been changed."))
    (if (/= newTolerance nil)
        (progn
            (vla-put-TolerancePrecision dimObj newTolerance)   ;; Commit changes to tolerance precision
            ;; Read back and display the dimension tolerance precision
            (alert (strcat "The tolerance precision has been set to " (itoa (vla-get-TolerancePrecision dimObj)) " decimal places"))
GMT+8, 2026-11-16 03:59
