TextOverride 属性 (ActiveX)
指定维度的文本字符串。 支持的平台:仅限 Windows 签名VBA: object.TextOverride 属性值只读:不 类型:字符串 最大长度为 256 个字符。 言论用户字符串将替换计算出的维度值。您可以通过将文本设置为字符串 (“”) 来恢复计算出的维度值。您可以使用一组闭合的括号 (<>) 来表示主维度值,从而在主维度值后附加文本或为其添加前缀。显示字符串时,主维度值将替换括号。例如,= “<> mm” 将导致显示一个字符串 “3.5 mm”,其中尺寸值为 3.5。还可以使用方括号 ( [] ) 包含二级维度值。NULLTextString 例子VBA: Sub Example_TextOverride()
' This example creates an aligned dimension and then changes the
' TextOverride property for that dimension.
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
location(0) = 7.5: location(1) = 5#: location(2) = 0#
ZoomAll
MsgBox "The initial text string for the dimension contains only the dimension value.", vbInformation, "TextOverride Example"
' Change the text string for the dimension
dimObj.TextOverride = "The value is <>"
dimObj.Update
MsgBox "The text string for the dimension has been replaced. However, the dimension value is still represented.", vbInformation, "TextOverride Example"
' Reset the text string for the dimension
dimObj.TextOverride = ""
dimObj.Update
MsgBox "The text string for the dimension is reset.", vbInformation, "TextOverride Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextOverride()
;; This example creates an aligned dimension and then changes the
;; TextOverride property for that dimension.
;; Define the dimension
(setq point1 (vlax-3d-point 5 3 0)
point2 (vlax-3d-point 10 3 0)
location (vlax-3d-point 7.5 5 0))
(vla-ZoomAll acadObj)
(alert "The initial text string for the dimension contains only the dimension value.")
;; Change the text string for the dimension
(vla-put-TextOverride dimObj "The value is <>")
(vla-Update dimObj)
(alert "The text string for the dimension has been replaced. However, the dimension value is still represented.")
;; Reset the text string for the dimension
(vla-put-TextOverride dimObj "")
(vla-Update dimObj)
(alert "The text string for the dimension is reset.")
GMT+8, 2026-11-16 04:15
