SurfaceNormals 属性 (ActiveX)
指定曲面垂直于横截面的横截面曲线。 支持的平台:仅限 Windows 属性值只读:
类型:长 垂直于曲面的横截面曲线。 言论没有其他评论。 例子VBA: Sub SurfaceProperties()
Set ssetObj = ThisDrawing.SelectionSets.Add("SURFACES2")
Dim mode As Integer
ssetObj.SelectOnScreen
Dim obj As AcadEntity
Dim extrude As AcadExtrudedSurface
Dim objName As String
Dim LayerName As String
For Each obj In ssetObj
objName = obj.ObjectName
If TypeOf obj Is AcadExtrudedSurface Then
ExtrudedSurfaceProperties obj
ElseIf TypeOf obj Is AcadRevolvedSurface Then
RevolvedSurfaceProperties obj
ElseIf TypeOf obj Is AcadLoftedSurface Then
LoftedSurfaceProperties obj
ElseIf TypeOf obj Is AcadSweptSurface Then
SweptSurfaceProperties obj
ElseIf TypeOf obj Is AcadPlaneSurface Then
PlaneSurfaceProperties obj
End If
Next
ssetObj.Delete
Private Sub ExtrudedSurfaceProperties(extrude As AcadExtrudedSurface)
GetSurfaceBoundingBox extrude
MsgBox "SurfaceType: " & extrude.SurfaceType & vbCr & _
"Height: " & extrude.height & vbCr & _
"TaperAngle: " & extrude.TaperAngle & vbCr & _
"Direction: " & extrude.Direction & vbCr & _
"Material: " & extrude.Material & vbCr & _
"UIsolineDensity: " & extrude.UIsolineDensity & vbCr & _
"VIsolineDensity: " & extrude.VIsolineDensity
'Now change the configurable properties
extrude.height = extrude.height * 1.5
extrude.TaperAngle = extrude.TaperAngle * (3.14 / 2)
extrude.UIsolineDensity = extrude.UIsolineDensity * 2#
extrude.VIsolineDensity = extrude.VIsolineDensity * 0.5
ThisDrawing.Regen acActiveViewport
Utility.GetString 0, "Press return to continue..."
'Now change the properties back to their original values
extrude.height = extrude.height / 1.5
extrude.TaperAngle = extrude.TaperAngle / (3.14 / 2)
extrude.UIsolineDensity = extrude.UIsolineDensity / 2#
extrude.VIsolineDensity = extrude.VIsolineDensity / 0.5
Private Sub RevolvedSurfaceProperties(revolve As AcadRevolvedSurface)
GetSurfaceBoundingBox revolve
MsgBox "SurfaceType: " & revolve.SurfaceType & vbCr & _
"RevolutionAngle: " & revolve.RevolutionAngle & vbCr & _
"AxisPosition: " & revolve.AxisPosition & vbCr & _
"AxisDirection: " & revolve.AxisDirection & vbCr & _
"Material: " & revolve.Material & vbCr & _
"UIsolineDensity: " & revolve.UIsolineDensity & vbCr & _
"VIsolineDensity: " & revolve.VIsolineDensity
revolve.RevolutionAngle = revolve.RevolutionAngle * (3.14 / 2)
revolve.UIsolineDensity = revolve.UIsolineDensity * 2#
revolve.VIsolineDensity = revolve.VIsolineDensity * 0.5
revolve.RevolutionAngle = revolve.RevolutionAngle / (3.14 / 2)
revolve.UIsolineDensity = revolve.UIsolineDensity / 2#
revolve.VIsolineDensity = revolve.VIsolineDensity / 0.5
Private Sub LoftedSurfaceProperties(lofted As AcadLoftedSurface)
GetSurfaceBoundingBox lofted
MsgBox "SurfaceType: " & lofted.SurfaceType & vbCr & _
"NumCrossSections: " & lofted.NumCrossSections & vbCr & _
"NumGuidePaths: " & lofted.NumGuidePaths & vbCr & _
"SurfaceNormals: " & lofted.SurfaceNormals & vbCr & _
"StartDraftAngle: " & lofted.StartDraftAngle & vbCr & _
"StartDraftMagnitude: " & lofted.StartDraftMagnitude & vbCr & _
"EndDraftAngle: " & lofted.EndDraftAngle & vbCr & _
"EndDraftMagnitude: " & lofted.EndDraftMagnitude & vbCr & _
"Closed: " & lofted.Closed & vbCr & _
"Material: " & lofted.Material & vbCr & _
"UIsolineDensity: " & lofted.UIsolineDensity & vbCr & _
"VIsolineDensity: " & lofted.VIsolineDensity
lofted.StartDraftAngle = lofted.StartDraftAngle * (3.14 / 2)
lofted.EndDraftAngle = lofted.EndDraftAngle * (3.14 / 4)
lofted.UIsolineDensity = lofted.UIsolineDensity * 2#
lofted.VIsolineDensity = lofted.VIsolineDensity * 0.5
lofted.StartDraftAngle = lofted.StartDraftAngle / (3.14 / 2)
lofted.EndDraftAngle = lofted.EndDraftAngle / (3.14 / 4)
lofted.UIsolineDensity = lofted.UIsolineDensity / 2#
lofted.VIsolineDensity = lofted.VIsolineDensity / 0.5
Private Sub SweptSurfaceProperties(swept As AcadSweptSurface)
GetSurfaceBoundingBox swept
MsgBox "SurfaceType: " & swept.SurfaceType & vbCr & _
"ProfileRotation: " & swept.ProfileRotation & vbCr & _
"Bank: " & swept.Bank & vbCr & _
"Twist: " & swept.Twist & vbCr & _
"scale: " & swept.scale & vbCr & _
"Length: " & swept.length & vbCr & _
"Material: " & swept.Material & vbCr & _
"UIsolineDensity: " & swept.UIsolineDensity & vbCr & _
"VIsolineDensity: " & swept.VIsolineDensity
swept.ProfileRotation = swept.ProfileRotation * 3.14 * 0.25
swept.Bank = Not swept.Bank
swept.Twist = swept.Twist * 3.14 * -0.5
swept.UIsolineDensity = swept.UIsolineDensity * 2#
swept.VIsolineDensity = swept.VIsolineDensity * 0.5
swept.ProfileRotation = swept.ProfileRotation / (3.14 * 0.25)
swept.Twist = swept.Twist / (3.14 * -0.5)
swept.UIsolineDensity = swept.UIsolineDensity / 2#
swept.VIsolineDensity = swept.VIsolineDensity / 0.5
Private Sub PlaneSurfaceProperties(planar As AcadPlaneSurface)
GetSurfaceBoundingBox planar
MsgBox "SurfaceType: " & planar.SurfaceType & vbCr & _
"UIsolineDensity: " & planar.UIsolineDensity & vbCr & _
"VIsolineDensity: " & planar.VIsolineDensity
planar.UIsolineDensity = planar.UIsolineDensity * 2#
planar.VIsolineDensity = planar.VIsolineDensity * 0.5
planar.UIsolineDensity = planar.UIsolineDensity / 2#
planar.VIsolineDensity = planar.VIsolineDensity / 0.5
Private Sub GetSurfaceBoundingBox(surf As AcadSurface)
Dim MinPoint As Variant
Dim MaxPoint As Variant
surf.GetBoundingBox MinPoint, MaxPoint
' Print the min and max extents
MsgBox "The extents of the bounding box for the surface are:" & vbCrLf _
& "Min Point: " & MinPoint(0) & "," & MinPoint(1) & "," & MinPoint(2) _
& vbCrLf & "Max Point: " & MaxPoint(0) & "," & MaxPoint(1) & "," & MaxPoint(2), vbInformation, "GetBoundingBox of Surface"
可视化 LISP: (vl-load-com)
(defun c:SurfaceProperties()
(setq ssetObj (vla-Add (vla-get-SelectionSets doc) "SURFACES2"))
(vla-SelectOnScreen ssetObj)
(vlax-for obj ssetObj
(setq objName (vla-get-ObjectName obj))
(cond
((= "AcDb3dSolid" objName)
(cond
((= (vla-get-SolidType obj) "Extrusion") (alert "Extruded solid selected."))
((= (vla-get-SolidType obj) "Revolve") (alert "Revolved solid selected."))
((= (substr (vla-get-SolidType obj) 1 4) "Loft") (alert "Lofted solid selected."))
((= (vla-get-SolidType obj) "Sweep") (alert "Swept solid selected."))
((= "AcDbExtrudedSurface" objName) (ExtrudedSurfaceProperties obj))
((= "AcDbRevolvedSurface" objName) (RevolvedSurfaceProperties obj))
((= "AcDbLoftedSurface" objName) (LoftedSurfaceProperties obj))
((= "AcDbSweptSurface" objName) (SweptSurfaceProperties obj))
((= "AcDbPlaneSurface" objName) (PlaneSurfaceProperties obj))
(vla-Delete ssetObj)
(defun ExtrudedSurfaceProperties (extrude / )
(GetSurfaceBoundingBox extrude)
(alert (strcat "SurfaceType: " (vla-get-SurfaceType extrude)
"\nHeight: " (rtos (vla-get-Height extrude) 2)
"\nTaperAngle: " (rtos (vla-get-TaperAngle extrude) 2)
"\nMaterial: " (vla-get-Material extrude)
"\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity extrude))
"\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity extrude))))
;; Now change the configurable properties
(vla-put-Height extrude (* (vla-get-Height extrude) 1.5))
(vla-put-TaperAngle extrude (* (vla-get-TaperAngle extrude) (/ 3.14 2)))
(vla-put-UIsolineDensity extrude (* (vla-get-UIsolineDensity extrude) 2))
(vla-put-VIsolineDensity extrude (* (vla-get-VIsolineDensity extrude) 0.5))
(vla-Regen doc acActiveViewport)
(vla-GetString (vla-get-Utility doc) 0 "Press return to continue...")
;; Now change the properties back to their original values
(vla-put-Height extrude (/ (vla-get-Height extrude) 1.5))
(vla-put-TaperAngle extrude (/ (vla-get-TaperAngle extrude) (/ 3.14 2)))
(vla-put-UIsolineDensity extrude (/ (vla-get-UIsolineDensity extrude) 2))
(vla-put-VIsolineDensity extrude (/ (vla-get-VIsolineDensity extrude) 0.5))
(defun RevolvedSurfaceProperties (revolve / )
(GetSurfaceBoundingBox revolve)
(alert (strcat "SurfaceType: " (vla-get-SurfaceType revolve)
"\nRevolutionAngle: " (rtos (vla-get-RevolutionAngle revolve) 2)
"\nMaterial: " (vla-get-Material revolve)
"\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity revolve))
"\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity revolve))))
(vla-put-RevolutionAngle revolve (* (vla-get-RevolutionAngle revolve) (/ 3.14 2)))
(vla-put-UIsolineDensity revolve (* (vla-get-UIsolineDensity revolve) 2))
(vla-put-VIsolineDensity revolve (* (vla-get-VIsolineDensity revolve) 0.5))
(vla-put-RevolutionAngle revolve (/ (vla-get-RevolutionAngle revolve) (/ 3.14 2)))
(vla-put-UIsolineDensity revolve (/ (vla-get-UIsolineDensity revolve) 2))
(vla-put-VIsolineDensity revolve (/ (vla-get-VIsolineDensity revolve) 0.5))
(defun LoftedSurfaceProperties (lofted / )
(GetSurfaceBoundingBox lofted)
(alert (strcat "SurfaceType: " (vla-get-SurfaceType lofted)
"\nNumCrossSections: " (itoa (vla-get-NumCrossSections lofted))
"\nNumGuidePaths: " (itoa (vla-get-NumGuidePaths lofted))
"\nSurfaceNormals: " (itoa (vla-get-SurfaceNormals lofted))
"\nStartDraftAngle: " (rtos (vla-get-StartDraftAngle lofted) 2)
"\nStartDraftMagnitude: " (rtos (vla-get-StartDraftMagnitude lofted) 2)
"\nEndDraftAngle: " (rtos (vla-get-EndDraftAngle lofted) 2)
"\nEndDraftMagnitude: " (rtos (vla-get-EndDraftMagnitude lofted) 2)
"\nClosed: " (if (= (vla-get-Closed lofted) :vlax-true) "True" "False")
"\nMaterial: " (vla-get-Material lofted)
"\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity lofted))
"\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity lofted))))
(vla-put-StartDraftAngle lofted (* (vla-get-StartDraftAngle lofted) (/ 3.14 2)))
(vla-put-EndDraftAngle lofted (* (vla-get-EndDraftAngle lofted) (/ 3.14 4)))
(vla-put-UIsolineDensity lofted (* (vla-get-UIsolineDensity lofted) 2))
(vla-put-VIsolineDensity lofted (* (vla-get-VIsolineDensity lofted) 0.5))
(vla-put-StartDraftAngle lofted (/ (vla-get-StartDraftAngle lofted) (/ 3.14 2)))
(vla-put-EndDraftAngle lofted (/ (vla-get-EndDraftAngle lofted) (/ 3.14 4)))
(vla-put-UIsolineDensity lofted (/ (vla-get-UIsolineDensity lofted) 2))
(vla-put-VIsolineDensity lofted (/ (vla-get-VIsolineDensity lofted) 0.5))
(defun SweptSurfaceProperties (swept / )
(GetSurfaceBoundingBox swept)
(alert (strcat "SurfaceType: " (vla-get-SurfaceType swept)
"\nProfileRotation: " (rtos (vla-get-ProfileRotation swept) 2)
"\nBank: " (if (= (vla-get-Bank swept) :vlax-true) "True" "False")
"\nTwist: " (rtos (vla-get-Twist swept) 2)
"\nscale: " (rtos (vla-get-Scale swept) 2)
"\nLength: " (rtos (vla-get-Length swept) 2)
"\nMaterial: " (vla-get-Material swept)
"\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity swept))
"\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity swept))))
(vla-put-ProfileRotation swept (* (vla-get-ProfileRotation swept) (* 3.14 0.25)))
(vla-put-Bank swept (if (= (vla-get-Bank swept) :vlax-true) :vlax-false :vlax-true))
(vla-put-Twist swept (* (vla-get-Twist swept) (* 3.14 -0.5)))
(vla-put-UIsolineDensity swept (* (vla-get-UIsolineDensity swept) 2))
(vla-put-VIsolineDensity swept (* (vla-get-VIsolineDensity swept) 0.5))
(vla-put-ProfileRotation swept (/ (vla-get-ProfileRotation swept) (* 3.14 0.25)))
(vla-put-Twist swept (/ (vla-get-Twist swept) (* 3.14 -0.5)))
(vla-put-UIsolineDensity swept (/ (vla-get-UIsolineDensity swept) 2))
(vla-put-VIsolineDensity swept (/ (vla-get-VIsolineDensity swept) 0.5))
(defun PlaneSurfaceProperties (planar / )
(GetSurfaceBoundingBox planar)
(alert (strcat "SurfaceType: " (vla-get-SurfaceType planar)
"\nUIsolineDensity: " (itoa (vla-get-UIsolineDensity planar))
"\nVIsolineDensity: " (itoa (vla-get-VIsolineDensity planar))))
(vla-put-UIsolineDensity planar (* (vla-get-UIsolineDensity planar) 2))
(vla-put-VIsolineDensity planar (* (vla-get-VIsolineDensity planar) 0.5))
(vla-put-UIsolineDensity planar (/ (vla-get-UIsolineDensity planar) 2))
(vla-put-VIsolineDensity planar (/ (vla-get-VIsolineDensity planar) 0.5))
(defun GetSurfaceBoundingBox (surf / )
(vla-GetBoundingBox surf 'MinPoint 'MaxPoint)
;; Print the min and max extents
(alert (strcat "The extents of the bounding box for the surface are:"
"\nMin Point: " (rtos (vlax-safearray-get-element MinPoint 0) 2) ","
(rtos (vlax-safearray-get-element MinPoint 1) 2) ","
(rtos (vlax-safearray-get-element MinPoint 2) 2)
"\nMax Point: " (rtos (vlax-safearray-get-element MaxPoint 0) 2) ","
(rtos (vlax-safearray-get-element MaxPoint 1) 2) ","
(rtos (vlax-safearray-get-element MaxPoint 2) 2)))
GMT+8, 2026-11-16 02:57
