RegisteredApplications 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1079| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 RegisteredApplications 集合。
object.RegisteredApplications
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:RegisteredApplications
文档的集合。RegisteredApplications
Sub Example_RegisteredApplications()
    ' This example finds the current RegisteredApplications collection and
    ' adds a new RegisteredApplication to that collection.
    Dim RegAppColl As AcadRegisteredApplications
    Set RegAppColl = ThisDrawing.RegisteredApplications
    ' Create a RegisteredApp named "TEST" in the current drawing
    Dim RegAppObj As AcadRegisteredApplication
    Set RegAppObj = RegAppColl.Add("TEST")
    MsgBox "A new registered application called " & RegAppObj.name & " has been added to the Registered Applications collection.", vbInformation, "RegisteredApplications Example"
(defun c:Example_RegisteredApplications()
    ;; This example finds the current RegisteredApplications collection and
    ;; adds a new RegisteredApplication to that collection.
    (setq RegAppColl (vla-get-RegisteredApplications doc))
    ;; Create a RegisteredApp named "TEST" in the current drawing
    (setq RegAppObj (vla-Add RegAppColl "TEST"))
    (alert (strcat "A new registered application called " (vla-get-Name RegAppObj) " has been added to the Registered Applications collection."))
GMT+8, 2026-11-16 02:52
