PickAdd 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1094| 评论: 0|原作者: admin|来自: AutoCAD
确定是否使用 Shift 键将对象添加到选择集中。
object.PickAdd
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:通过在选择时按住 Shift 键将对象添加到当前选择集。
  • False:通过在选择时按住 Shift 键从选择集中删除对象。
此属性的初始值为 False。
注意:此属性的值存储在 PICKADD 系统变量中。
Sub Example_PickAdd()
    ' This example reads and modifies the preference value that controls
    ' whether objects are added to the selection set using the SHIFT key.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickAdd
    MsgBox "The PickAdd preference is set to: " & originalValue
    ' Modify the PickAdd preference by toggling the value
    ACADPref.PickAdd = Not (ACADPref.PickAdd)
    newValue = ACADPref.PickAdd
    MsgBox "The PickAdd preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickAdd = originalValue
    MsgBox "The PickAdd preference was reset back to: " & originalValue
(defun c:Example_PickAdd()
    ;; This example reads and modifies the preference value that controls
    ;; whether objects are added to the selection set using the SHIFT key.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickAdd (vla-get-Selection preferences)))
    (alert (strcat "The PickAdd preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PickAdd preference by toggling the value
    (vla-put-PickAdd (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PickAdd (vla-get-Selection preferences)))
    (alert (strcat "The PickAdd preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PickAdd (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickAdd preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-16 04:20
