OLEQuality 属性 (ActiveX)
指定 OLE 对象的打印质量。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acOleQuality
言论此属性的初始值为 。acOQText 注意:此属性的值存储在 OLQUALITIES 系统变量中。
例子VBA: Sub Example_OLEQuality()
' This example reads and modifies the preference value that controls
' the plot quality of OLE objects. When finished, this example resets
' the preference value back to its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalValue As Variant, DisplayValue As String
' Get the output preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
' Store original value
originalValue = ACADPref.OLEQuality
GoSub GETVALUE
MsgBox "The OLEQuality preference is currently set to: " & DisplayValue
' Modify the OLEQuality preference by changing it to High Quality Photographic
ACADPref.OLEQuality = acOQHighPhoto
GoSub GETVALUE
MsgBox "The OLEQuality preference has been set to: " & DisplayValue
' this preference in effect
ACADPref.OLEQuality = originalValue
GoSub GETVALUE
MsgBox "The OLEQuality preference was reset back to: " & DisplayValue
Exit Sub
GETVALUE:
' Convert the value of this setting to a meaningful text string
DisplayValue = ACADPref.OLEQuality
Select Case DisplayValue
Case acOQLineArt: DisplayValue = "Line Art"
Case acOQText: DisplayValue = "Text"
Case acOQGraphics: DisplayValue = "Graphics"
Case acOQPhoto: DisplayValue = "Photo"
Case acOQHighPhoto: DisplayValue = "High Photo"
End Select
Return
可视化 LISP: (vl-load-com)
(defun c:Example_OLEQuality()
;; This example reads and modifies the preference value that controls
;; the plot quality of OLE objects. When finished, this example resets
;; the preference value back to its original value.
;; Store original value
(setq originalValue (vla-get-OLEQuality (vla-get-Output preferences)))
(setq DisplayValue (cond
((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQLineArt) "Line Art")
((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQText) "Text")
((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQGraphics) "Graphics")
((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQPhoto) "Photo")
((= (vla-get-OLEQuality (vla-get-Output preferences)) acOQHighPhoto) "High Photo")
(alert (strcat "The OLEQuality preference is currently set to: " DisplayValue))
;; Modify the OLEQuality preference by changing it to High Quality Photographic
(vla-put-OLEQuality (vla-get-Output preferences) acOQHighPhoto)
(alert (strcat "The OLEQuality preference has been set to: " DisplayValue))
;; this preference in effect
(vla-put-OLEQuality (vla-get-Output preferences) originalValue)
(alert (strcat "The OLEQuality preference was reset back to: " DisplayValue))
GMT+8, 2026-11-16 04:45
