MomentOfInertia 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 732| 评论: 0|原作者: admin|来自: AutoCAD
获取固体的惯性矩。
object.MomentOfInertia
类型:3DSolid、区域
此属性应用于的对象。
只读:是的
类型:变体(双元素或三元素的双精度数组)
基于当前坐标系的 2D 或 3D 坐标。
转动惯量返回为定义为变体的 X、Y 和 Z 坐标。
Sub Example_MomentOfInertia2D()
    ' This example creates a region in model space.
    ' It then returns the MomentOfInertia for that region.
    Dim curves(0 To 1) As AcadEntity
    ' Define the arc
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).StartPoint, curves(0).EndPoint)
    ' Create the region
    Dim regionObjArr As Variant
    regionObjArr = ThisDrawing.ModelSpace.AddRegion(curves)
    ZoomAll
    ' Return the MomentOfInertia for the region
    Dim regionObj As AcadRegion
    Set regionObj = regionObjArr(0)
    Dim momentOfInertia As Variant
    momentOfInertia = regionObj.momentOfInertia
    MsgBox "The MomentOfInertia for the region is " & momentOfInertia(0) & "," & momentOfInertia(1), , "MomentOfInertia Example"
Sub Example_MomentOfInertia3D()
    ' This example creates a box in model space.
    ' It then returns the MomentOfInertia for that box.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Change the viewing direction of the viewport to better see the box
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
    ' Return the MomentOfInertia for the box
    momentOfInertia = boxObj.momentOfInertia
    MsgBox "The MomentOfInertia for the box is " & momentOfInertia(0) & "," & momentOfInertia(1) & "," & momentOfInertia(2), , "MomentOfInertia Example"
(defun c:Example_MomentOfInertia2D()
    ;; This example creates a region in model space.
    ;; It then returns the MomentOfInertia for that region.
          doc (vla-get-ActiveDocument acadObj)
          modelSpace (vla-get-ModelSpace doc))
    ;; Define the arc
    (setq centerPoint (vlax-3d-point 5 3 0)
          radius 2
          startAngle 0
          endAngle 3.141592)
    (setq arc (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
    ;; Define the line
    (setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
    (setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element curves 0 arc)
    (vlax-safearray-put-element curves 1 line)
    ;; Create the region
    (setq regionObjArr (vla-AddRegion modelSpace curves))
    (vla-ZoomAll acadObj)
    ;; Return the MomentOfInertia for the region
    (setq regionObj (vlax-safearray-get-element (vlax-variant-value regionObjArr) 0)
          momentOfInertia (vlax-variant-value (vla-get-MomentOfInertia regionObj)))
    (alert (strcat "The MomentOfInertia for the region is "
                   (rtos (vlax-safearray-get-element momentOfInertia 0) 2) ","
                   (rtos (vlax-safearray-get-element momentOfInertia 1) 2)))
;; The following example only applies to AutoCAD and not AutoCAD LT
(defun c:Example_MomentOfInertia3D()
    ;; This example creates a box in model space.
    ;; It then returns the MomentOfInertia for that box.
          doc (vla-get-ActiveDocument acadObj))
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
          boxWidth 7
          boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq modelSpace (vla-get-ModelSpace doc)
          boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Change the viewing direction of the viewport to better see the box
    (setq NewDirection (vlax-3d-point -1 -1 1)
          activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    ;; Return the MomentOfInertia for the box
    (setq momentOfInertia (vlax-variant-value (vla-get-MomentOfInertia boxObj)))
    (alert (strcat "The MomentOfInertia for the box is "
                   (rtos (vlax-safearray-get-element momentOfInertia 1) 2) ","
                   (rtos (vlax-safearray-get-element momentOfInertia 2) 2)))
GMT+8, 2026-11-16 04:46
