Materials 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1067| 评论: 0|原作者: admin|来自: AutoCAD
返回数据库的材料集合。
object.Materials
类型:数据库、文档
应用此属性的对象。
只读:是的
类型: 材料
数据库的集合。Materials
Sub Example_AddMaterial()
    Dim oMaterial As AcadMaterial
    Dim oMaterials As AcadMaterials
    Set oMaterial = ThisDrawing.Materials.Add("TestMaterial")
    oMaterial.Description = "This material demonstrates how to add a material to a database."
    ThisDrawing.ActiveMaterial = oMaterial
    ' Display the name and description of the layer
    MsgBox oMaterial.Name & " has been added." & vbCrLf & _
            "Name: " & vbCrLf & oMaterial.Name & vbCrLf & vbCrLf & _
            "Description: " & vbCrLf & _
(defun c:Example_Materials()
          doc (vla-get-ActiveDocument acadObj))
    (if (= (strcase (getvar "PROGRAM") T) "acad")
        (progn
            (setq oMaterial (vla-Add (vla-get-Materials doc) "TestMaterial"))
            (vla-put-Description oMaterial "This material demonstrates how to add a material to a database.")
            (vla-put-ActiveMaterial doc oMaterial)
        (setq oMaterial (vla-get-ActiveMaterial doc))
    ;; Display the status of the new layer
    (alert (strcat (vla-get-Name oMaterial) " has been added."
                   "\nName: " (vla-get-Name oMaterial)
                   "\nDescription: " (vla-get-Description oMaterial)))
GMT+8, 2026-11-16 04:05
