Mask 属性 (ActiveX)
指定要恢复的图层属性。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 属性值只读:不 类型:枚举AcLayerStateMask 表示要恢复的图层属性的数字。使用下表中的常量来标识图层属性:
言论LayerStateManager 方法使用 Mask 属性来标识要还原的图层属性。首先,在使用 LayerStateManager 方法保存图层设置时设置该属性。但是,Save 方法实际上保存了每个绘图图层的所有属性。您可以在恢复图层设置之前随时更新属性,从而更改要恢复的图层属性。RestoreMaskSaveMask 要在蒙版中指定多个图层属性,请添加表示这些属性的常量。例如,若要保存 Color 和 LineType 属性,请指定以下内容: acLsColor + acLsLineType 例子VBA: Sub Example_SetMask()
' The following code updates the Mask property of layer
' settings saved under the name "ColorLineType, so that
' Color, LineType, and LineWeight layer properties will
' be restored by a Restore operation.
Dim oLSM As AcadLayerStateManager
Dim settings As AcLayerStateMask
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
oLSM.SetDatabase ThisDrawing.Database
oLSM.Save "ColorLinetype", acLsColor + acLsLineType
' Retrieve the current mask setting from ColorLinetype
settings = oLSM.Mask("ColorLinetype")
' Set mask so that Color, LineType, and LineWeight
' properties will be restored by a Restore operation
settings = acLsColor + acLsLineType + acLsLineWeight
' Commit the new settings mask to ColorLinetype
oLSM.Mask("ColorLinetype") = settings
可视化 LISP: (vl-load-com)
(defun c:Example_Mask()
;; The following code updates the Mask property of layer
;; settings saved under the name "ColorLineType, so that
;; Color, LineType, and LineWeight layer properties will
;; be restored by a Restore operation.
doc (vla-get-ActiveDocument acadObj))
(setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
(vla-SetDatabase oLSM (vla-get-Database doc))
(vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
;; Retrieve the current mask setting from ColorLinetype
(setq settings (vla-get-Mask oLSM "ColorLinetype"))
;; Set mask so that Color, LineType, and LineWeight
;; properties will be restored by a Restore operation
(setq settings (+ acLsColor acLsLineType acLsLineWeight))
;; Commit the new settings mask to ColorLinetype
(vla-put-Mask oLSM "ColorLinetype" settings)
GMT+8, 2026-11-16 00:41
