MajorAxis 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 873| 评论: 0|原作者: admin|来自: AutoCAD
指定椭圆的长轴方向。
object.MajorAxis
类型:椭圆
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
定义主轴的 3D 矢量。向量起源于椭圆中心。
椭圆的长轴称为长轴;较短的是短轴。
Sub Example_MajorAxis()
    ' This example creates an ellipse and finds the major axis
    ' for that ellipse. It then changes the major axis for the ellipse.
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    ' Create an ellipse in model space
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ellObj.Update
    MsgBox "The ellipse has a major axis of " & majAxis(0) & ", " & majAxis(1) & ", " & majAxis(2), vbInformation, "MajorAxis Example"
    ' Change the major axis of the ellipse
    majAxis(0) = 5: majAxis(1) = 5: majAxis(2) = 0
    ellObj.MajorAxis = majAxis
    ellObj.Update
    ' Query the major axis of an Ellipse
    Dim retMajAxis As Variant
    retMajAxis = ellObj.MajorAxis
    MsgBox "The ellipse has been udpated with the major axis " & retMajAxis(0) & ", " & retMajAxis(1) & ", " & retMajAxis(2), vbInformation, "MajorAxis Example"
(defun c:Example_MajorAxis()
    ;; This example creates an ellipse and finds the major axis
    ;; for that ellipse. It then changes the major axis for the ellipse.
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    (vla-Update ellObj)
    (setq majAxis (vlax-variant-value majAxis))
    (alert (strcat "The ellipse has a major axis of " (rtos (vlax-safearray-get-element majAxis 0) 2) ", "
                                                      (rtos (vlax-safearray-get-element majAxis 1) 2) ", "
                                                      (rtos (vlax-safearray-get-element majAxis 2) 2)))
    ;; Change the major axis of the ellipse
    (setq majAxis (vlax-3d-point 5 5 0))
    (vla-put-MajorAxis ellObj majAxis)
    (vla-Update ellObj)
    ;; Query the major axis of an Ellipse
    (setq retMajAxis (vlax-variant-value (vla-get-MajorAxis ellObj)))
    (alert (strcat "The ellipse has been udpated with the major axis " (rtos (vlax-safearray-get-element retMajAxis 0) 2) ", "
        (rtos (vlax-safearray-get-element retMajAxis 1) 2) ", "
        (rtos (vlax-safearray-get-element retMajAxis 2) 2)))
GMT+8, 2026-11-16 01:57
