LoadAcadLspInAllDocuments 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 737| 评论: 0|原作者: admin|来自: AutoCAD
指定 acad.lsp 是在启动时加载还是在每个图形中加载。
object.LoadAcadLspInAllDocuments
类型:PreferencesSystem
此属性应用于的对象。
只读:不
类型:布尔
  • True:acad.lsp 随每个图形一起加载。
  • False:acad.lsp 仅在启动时与第一张图形一起加载。
此属性的初始值为 。True
注意:此属性的值存储在 ACADLSPASDOC 系统变量中。
Sub Example_LoadAcadLspInAllDocuments()
    ' LoadAcadLspInAllDocuments. It then changes the value, and finally
    Dim currLoadAcadLspInAllDocuments As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current LoadAcadLspInAllDocuments value
    currLoadAcadLspInAllDocuments = preferences.System.LoadAcadLspInAllDocuments
    MsgBox "The current value for LoadAcadLspInAllDocuments is " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
    ' Change the value for LoadAcadLspInAllDocuments
    preferences.System.LoadAcadLspInAllDocuments = Not (currLoadAcadLspInAllDocuments)
    MsgBox "The new value for LoadAcadLspInAllDocuments is " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
    ' Reset LoadAcadLspInAllDocuments to its original value
    preferences.System.LoadAcadLspInAllDocuments = currLoadAcadLspInAllDocuments
    MsgBox "The LoadAcadLspInAllDocuments value is reset to " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
(defun c:Example_LoadAcadLspInAllDocuments()
    ;; LoadAcadLspInAllDocuments. It then changes the value, and finally
    ;; Retrieve the current LoadAcadLspInAllDocuments value
    (setq currLoadAcadLspInAllDocuments (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)))
    (alert (strcat "The current value for LoadAcadLspInAllDocuments is " (if (= currLoadAcadLspInAllDocuments :vlax-true) "True" "False")))
    ;; Change the value for LoadAcadLspInAllDocuments
    (vla-put-LoadAcadLspInAllDocuments (vla-get-System preferences) (if (= currLoadAcadLspInAllDocuments :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for LoadAcadLspInAllDocuments is " (if (= (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)) :vlax-true) "True" "False")))
    ;; Reset LoadAcadLspInAllDocuments to its original value
    (vla-put-LoadAcadLspInAllDocuments (vla-get-System preferences) currLoadAcadLspInAllDocuments)
    (alert (strcat "The LoadAcadLspInAllDocuments value is reset to " (if (= (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-16 04:11
