LastHeight 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1029| 评论: 0|原作者: admin|来自: AutoCAD
指定上次使用的文本高度。
object.LastHeight
类型:TextStyle
此属性应用于的对象。
只读:不
类型:双
用于文本样式的最后一个文本高度。
Sub Example_LastHeight()
    ' This example finds the current value for LastHeight.
    ' It then changes that value, and resets it again.
    Dim txtStyleObj As AcadTextStyle
    Set txtStyleObj = ThisDrawing.ActiveTextStyle
    ' Set and retrieve the LastHeight property
    Dim currHeight As Double
    Dim newHeight As Double
    ' Retrieve current LastHeight property
    currHeight = txtStyleObj.lastHeight
    MsgBox "The current value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example"
    ' Set LastHeight to a new value
    txtStyleObj.lastHeight = 4#
    ' Retrieve the current LastHeight value
    newHeight = txtStyleObj.lastHeight
    MsgBox "The new value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example"
    ' Finally reset LastHeight to its default value
    txtStyleObj.lastHeight = currHeight
    MsgBox "The value for LastHeight has been reset to " & txtStyleObj.lastHeight, , "LastHeight Example"
(defun c:Example_LastHeight()
    ;; This example finds the current value for LastHeight.
    ;; It then changes that value, and resets it again.
    (setq txtStyleObj (vla-get-ActiveTextStyle doc))
    ;; Set and retrieve the LastHeight property
    ;; Retrieve current LastHeight property
    (setq currHeight (vla-get-LastHeight txtStyleObj))
    (alert (strcat "The current value for LastHeight is " (rtos currHeight 2)))
    ;; Set LastHeight to a new value
    (vla-put-LastHeight txtStyleObj 4)
    ;; Retrieve the current LastHeight value
    (setq newHeight (vla-get-LastHeight txtStyleObj))
    (alert (strcat "The new value for LastHeight is " (rtos newHeight 2)))
    ;; Finally reset LastHeight to its default value
    (vla-put-LastHeight txtStyleObj currHeight)
    (alert (strcat "The value for LastHeight has been reset to " (rtos currHeight 2)))
GMT+8, 2026-11-16 03:18
