Issuer 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 911| 评论: 0|原作者: admin|来自: AutoCAD
Issuer 属性 (ActiveX)
指定数字证书的颁发者名称。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.Issuer
类型:SecurityParams
此属性应用于的对象。
只读:不
类型:字符串
数字证书的颁发者名称。
Sub Example_Issuer()
    ' This example attaches a digital signature and accompanying data to a file,
    ' and saves the file.
    Dim sp As AcadSecurityParams
    Set sp = GetInterfaceObject("AutoCAD.SecurityParams." & Left(AcadApplication.Version, 2))
    ' Attach a digital signature and timestamp it
    sp.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_SIGN_DATA _
                + AcadSecurityParamsType.ACADSECURITYPARAMS_ADD_TIMESTAMP
    ' Certificate details follow
    sp.Subject = "Thawte Freemail Member"
    sp.Issuer = "Personal Freemail RSA 2000.8.30"
    sp.SerialNumber = "073848"
    sp.Comment = "This is now signed"
    sp.TimeServer = "NIST(time.nist.gov)"
    ThisDrawing.SaveAs "C:\MyDrawing.dwg", , sp
(defun c:Example_Issuer()
    ;; This example attaches a digital signature and accompanying data to a file,
    ;; and saves the file.
          sp (vla-GetInterfaceObject (strcat "AutoCAD.SecurityParams." (substr (getvar "ACADVER") 1 2))))
    (vla-put-Visible acadObj :vlax-true)
    ;; Attach a digital signature and timestamp it
    (vla-put-Action sp (+ ACADSECURITYPARAMS_SIGN_DATA
                          ACADSECURITYPARAMS_ADD_TIMESTAMP))
    ;; Certificate details follow
    (vla-put-Subject sp "Thawte Freemail Member")
    (vla-put-Issuer sp "Personal Freemail RSA 2000.8.30")
    (vla-put-SerialNumber sp "073848")
    (vla-put-Comment sp "This is now signed")
    (vla-put-TimeServer sp "NIST(time.nist.gov)")
    (vla-SaveAs doc "C:\\MyDrawing.dwg" acNative sp)
    (vlax-release-object sp)
GMT+8, 2026-11-16 00:53
