HistoryLines 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1026| 评论: 0|原作者: admin|来自: AutoCAD
指定文本窗口中要保留在内存中的文本行数。
object.HistoryLines
类型:首选项显示
此属性应用于的对象。
只读:不
类型:整数
初始值为 400。
Sub Example_HistoryLines()
    ' HistoryLines. It then changes the value, and finally
    Dim currHistoryLines As Integer
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current HistoryLines value
    currHistoryLines = preferences.DISPLAY.HistoryLines
    MsgBox "The current value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
    ' Change the value for HistoryLines
    preferences.DISPLAY.HistoryLines = 42
    MsgBox "The new value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
    ' Reset HistoryLines to its original value
    preferences.DISPLAY.HistoryLines = currHistoryLines
    MsgBox "The HistoryLines value is reset to " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example"
(defun c:Example_HistoryLines()
    ;; HistoryLines. It then changes the value, and finally
    ;; Retrieve the current HistoryLines value
    (setq currHistoryLines (vla-get-HistoryLines (vla-get-Display preferences)))
    (alert (strcat "The current value for HistoryLines is " (itoa currHistoryLines)))
    ;; Change the value for HistoryLines
    (vla-put-HistoryLines (vla-get-Display preferences) 42)
    (alert (strcat "The new value for HistoryLines is " (itoa (vla-get-HistoryLines (vla-get-Display preferences)))))
    ;; Reset HistoryLines to its original value
    (vla-put-HistoryLines (vla-get-Display preferences) currHistoryLines)
    (alert (strcat "The HistoryLines value is reset to " (itoa (vla-get-HistoryLines (vla-get-Display preferences)))))
GMT+8, 2026-11-16 04:17
