HatchObjectType 属性 (ActiveX)
指定填充线的类型,经典或渐变。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举AcHatchObjectType
言论此属性的默认值为 0, ,这将创建一个经典的填充线。acHatchObject 如果此属性的值为 1, ,则通过创建填充线的方法创建渐变。如果创建了渐变,则应且应包含梯度图案名称 LINEAR、CYLINDER、INVCYLINDER、SPHERICAL、HEMISPHERICAL、CURVED、INVSPHERICAL、INVHEMISPHERICAL 或 INVCURVED。acGradientObjectAddHatchPatternTypeAcGradientPatternTypePatternName 例子VBA: Sub Example_HatchObjectType()
' This example changes the value of the HatchObjectType property.
' The example requires that the active drawing contain an existing hatch.
Dim ent As AcadHatch
Dim util As AcadUtility
Set util = ThisDrawing.Utility
Dim pt As Variant
Call util.GetEntity(ent, pt, "Select hatch :")
With ent
MsgBox "Initial value of HatchObjectType = " & .HatchObjectType
.HatchObjectType = acGradientObject
.GradientAngle = 3.1415 / 4
.GradientCentered = False
.GradientName = "SPHERICAL"
Dim col1 As AcadAcCmColor, col2 As AcadAcCmColor
Set col1 = .GradientColor1
Set col2 = .GradientColor2
col1.SetRGB 255, 0, 0
col2.SetRGB 0, 255, 0
.GradientColor1 = col1
.GradientColor2 = col2
MsgBox "New value of HatchObjectType = " & .HatchObjectType
End With
可视化 LISP: (vl-load-com)
(defun c:Example_HatchObjectType()
;; This example changes the value of the HatchObjectType property.
;; The example requires that the active drawing contain an existing hatch.
doc (vla-get-ActiveDocument acadObj)
util (vla-get-Utility doc))
(vla-GetEntity util 'ent 'pt "Select hatch :")
(alert (strcat "Initial value of HatchObjectType = " (itoa (vla-get-HatchObjectType ent))))
(vla-put-HatchObjectType ent acGradientObject)
(vla-put-GradientAngle ent (/ 3.1415 4))
(vla-put-GradientCentered ent :vlax-false)
(vla-put-GradientName ent "SPHERICAL")
(setq col1 (vla-get-GradientColor1 ent)
col2 (vla-get-GradientColor1 ent))
(vla-SetRGB col1 255 0 0)
(vla-SetRGB col2 0 255 0)
(vla-put-GradientColor1 ent col1)
(vla-put-GradientColor2 ent col2)
(alert (strcat "New value of HatchObjectType = " (itoa (vla-get-HatchObjectType ent))))
GMT+8, 2026-11-16 04:43
