FontFile 属性 (ActiveX)
指定主字体文件名,该文件名包含组成字符集的文本字符形状的定义。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 主字体文件路径。 言论若要指定亚洲语言字体文件,请使用该属性。BigFontFile 在某些情况下,更改分配给文本样式的字体文件后,字体名称可能无法正确更新。最常见的情况是在打开图形文件期间发生字体替换之后。建议使用对象的属性和方法同时更改字体文件和字体名称(字体)。有关使用字体的详细信息,请参阅《ActiveX 开发人员指南》中的关于分配字体。FontFileSetFontTextStyle 注意:设置此属性后,必须调用该方法以查看对文本的更改。Regen
例子VBA: Sub Example_FontFile()
' the FontFile property. It then changes the value, and
' finally resets the value back to the original setting.
Dim textStyle1 As AcadTextStyle
Dim currFontFile As String
Dim newFontFile As String
Set textStyle1 = ThisDrawing.ActiveTextStyle
' Retrieve the current FontFile value
currFontFile = textStyle1.fontFile
MsgBox "The current value for FontFile is " & currFontFile, vbInformation, "FontFile Example"
' Change the value for FontFile
newFontFile = "C:/AutoCAD/Fonts/italic.shx"
textStyle1.fontFile = newFontFile
MsgBox "The new value for FontFile is " & textStyle1.fontFile, vbInformation, "FontFile Example"
' Reset font file
textStyle1.fontFile = currFontFile
MsgBox "The value for FontFile has been reset to " & textStyle1.fontFile, vbInformation, "FontFile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_FontFile()
;; the FontFile property. It then changes the value, and
;; finally resets the value back to the original setting.
(setq textStyle1 (vla-get-ActiveTextStyle doc))
;; Retrieve the current FontFile value
(setq currFontFile (vla-get-FontFile textStyle1))
(alert (strcat "The current value for FontFile is " currFontFile))
;; Change the value for FontFile
(setq newFontFile (findfile "./Fonts/italic.shx"))
(vla-put-FontFile textStyle1 newFontFile)
(alert (strcat "The new value for FontFile is " (vla-get-FontFile textStyle1)))
;; Reset font file
(if (= (findfile currFontFile) nil)
(setq currFontFile (findfile (strcat (getenv "WinDir") "\\Fonts\\" currFontFile)))
(vla-put-FontFile textStyle1 (findfile currFontFile))
(alert (strcat "The value for FontFile has been reset to " (vla-get-FontFile textStyle1)))
GMT+8, 2026-11-16 03:01
