ExtensionLineWeight 属性 (ActiveX)
2024-5-18 19:21| 发布者: admin| 查看: 1052| 评论: 0|原作者: admin|来自: AutoCAD
指定延长线的线宽。
object.ExtensionLineWeight
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimOrdinate、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acLineWeight
  • acLnWtByLayer
  • acLnWtByBlock
  • acLnWtByLwDefault
  • acLnWt000
  • acLnWt005
  • acLnWt009
  • acLnWt013
  • acLnWt015
  • acLnWt018
  • acLnWt020
  • acLnWt025
  • acLnWt030
  • acLnWt035
  • acLnWt040
  • acLnWt050
  • acLnWt053
  • acLnWt060
  • acLnWt070
  • acLnWt080
  • acLnWt090
  • acLnWt100
  • acLnWt106
  • acLnWt120
  • acLnWt140
  • acLnWt158
  • acLnWt200
  • acLnWt211
此属性的初始值为 。acLnWtByBlock
仅当属性设置为 时,线宽设置才可见。LineweightDisplayTrue
注意:此属性将覆盖给定维度的 DIMLWE 系统变量的值。
Sub Example_ExtensionLineWeight()
    ' This example creates a Dim3PointAngular object in model space
    ' and changes the extension lineweight to a thicker value
    ' using the ExtensionLineWeight property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim oldLWSetting As Boolean
    Dim CurrentSetting As String
    ' Turn on lineweight display to see the changes
    oldLWSetting = ThisDrawing.preferences.LineWeightDisplay
    ThisDrawing.preferences.LineWeightDisplay = True
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current extension lineweight
    CurrentSetting = DimPointAngularObj.ExtensionLineWeight
    Select Case CurrentSetting
        Case acLnWtByLayer: CurrentSetting = "ByLayer"
        Case acLnWtByBlock: CurrentSetting = "ByBlock"
        Case acLnWtByLwDefault: CurrentSetting = "ByDefault"
        Case Else
    End Select
    MsgBox "The extension lineweight for this object is currently set to: " & CurrentSetting
    ' Change the extension lineweight
    DimPointAngularObj.ExtensionLineWeight = acLnWt100
    MsgBox "The extension line weight for this object is now set to: " & DimPointAngularObj.ExtensionLineWeight
    ' Return previous lineweight setting
    ThisDrawing.preferences.LineWeightDisplay = oldLWSetting
(defun c:Example_ExtensionLineWeight()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and changes the extension lineweight to a thicker value
    ;; using the ExtensionLineWeight property
    (setq preferences (vla-get-Preferences doc))
    ;; Turn on lineweight display to see the changes
    (setq oldLWSetting (vla-get-LineWeightDisplay preferences))
    (vla-put-LineWeightDisplay preferences :vlax-true)
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current extension lineweight
    (setq CurrentSetting (vla-get-ExtensionLineWeight DimPointAngularObj))
    (cond
        ((= acLnWtByLayer CurrentSetting)(setq CurrentSetting "ByLayer"))
        ((= acLnWtByBlock CurrentSetting)(setq CurrentSetting "ByBlock"))
        ((= acLnWtByLwDefault CurrentSetting)(setq CurrentSetting "ByDefault"))
	                                            (setq CurrentSetting (itoa CurrentSetting))
    (alert (strcat "The extension lineweight for this object is currently set to: " CurrentSetting))
    ;; Change the extension lineweight
    (vla-put-ExtensionLineWeight DimPointAngularObj acLnWt100)
    (alert (strcat "The extension line weight for this object is now set to: " (itoa (vla-get-ExtensionLineWeight DimPointAngularObj))))
    ;; Return previous lineweight setting
    (vla-put-ExtensionLineWeight DimPointAngularObj oldLWSetting)
GMT+8, 2026-11-16 03:58
